Where's the Duet Wifi 3?
if you don't waste the RAM chips, you can still get an RPi4 for 35$.
Thanks for that. Looks like a 2GB Pi4 is $35ish - I'd get the 8GB one because more is "more better" as they sayBuhu Its too expensive.
There is a cheaper option.
But I want the expensive one
... lol + facepalm + thumb down ...
The Duet3 mini (aka 5LC) is the next version of the Duet 2 Maestro, the low end, (relatively) low cost offering. So complaining about it not being as fully featured as the Duet 3 6HC or Duet 2 Wifi/Ethernet makes about as much sense as the rest of of the nonsense you're complaining about as it has a completely different customer base.
I guess I'll leave this thread by dropping the bomb that the CAN bus (currently) in use on both the Duet 3 6HC and mini is CAN-FD, so odds are it won't work with servos (but you'd know that if you bothered to search the forum)
Please - Facepalm yourself a few more times. In fact, keep doing it until I tell you to stop. You didn't comprehend the 'issue'. Go read it again as you seem to have only read the parts that suit you. If you had read my post up-thread, you would get it:
@BDubs said in Where's the Duet Wifi 3?:
- Faster processor speed (300Mhz vs 120MHz)
- Higher current onboard drivers for NEMA23/34 motors
- More GPIO
etc, etc...
Why settle for less?
I'm fully aware that the Mini 5 is wireless and has less I/O and processor speed than the Duet 3. I don't want it. It doesn't have enough I/O and the onboard drivers don't have enough amps for the motors I want to run. I have already stated this up-thread.
Furthermore - to get what I want in the latest form - it's twice the cost. Somehow me pointing that out is now whining? What do you think that the price is going to come down because I pointed out a simple observation? The price is what it is - doesn't mean I have to like it - AND it doesn't give you carte blanche to be a douche. Take it down a notch.
I would agree that for normal usage i love my duet2 wifi boards...i have 5 of them running on my printers, but for my cnc the duet 2 wifi is not enough because the motors i use are way more power hunger than the tmc2660 could do...so thinking that if i have to buy and use duet 3 board i need to run ethernet cable to be able to use it in standalone mode, witch is a no go for me, and buying a sbc board just to have wifi for a board that already have a high cost is no go as well...
So for me the obvious solution now is to use either duet2wifi with external stepper drivers or to use skr board with rrf firmware(this last is no brainer in terms of cost...)
So 1 more vote from me for a duet 3 board with wifi on it -
@deckingman said in Where's the Duet Wifi 3?:
I'm still waiting for a stable version of RRF3 to verify if the step pulse frequency is now as good as the older gen 2 product.
It's very much better now. https://docs.google.com/spreadsheets/d/1AWA1wLbOaYzxzdQa5LRZvn9rgEk2BuluHy6-_OnD6FY/edit#gid=0
................... - processor, or rather pulse rate, was the original yard stick when choosing the Duet. Not the same logic as most who are in dreamworld about speed...more like being able to run say 10:1 mechanical reduction and set the driver to full stepping to mitigate the hysteresis associated with microstepping (and torque loss on top of it) - but that's crazy talk because few can ever fathom what I just wrote and the reason behind it.
I'd be interested to know if RRF3 is on par with RRF2 in terms of max pulse rate, too. I'm config'd with RRF3 right now...but may go back to RRF2 after reading what you wrote.
If that is you usage case, then Duet 3 will be more than adequate in terms of step pulse frequency - even with the old firmware (but of course, you still have the WiFi access problem). For my particular usage case, the requirement stemmed from the need to use>16X micro stepping (ideally as high as 128X) in order to attain the necessary extruder resolution when using a mixing hot end and where one or more filament moves might be single digit percentages of the whole. For normal extruder moves, even such a high micro-step setting isn't a problem but it is when retracting. Like you, I foolishly thought that the higher processor speed would lead to increased performance in that respect so it was more than a little disappointing to find that it was actually much worse (but that may be fixed in the latest firmware).
One other thing about using an SBC for WiFi access is that one first has to wait for the SBC to boot before the Duet itself boots up. That additional boot up time could problematic depending on your usage case.
If it wasn't for the fact that I run >12 stepper motors, I'd be putting the gen 2 Duet back. I do have wired Ethernet so I run the Duet3 in stand alone mode because the RPi doesn't give me any additional functionality to compensate for all it's downsides (I've removed the RPi completely and repurposed it to run home automation instead).
One thing that might sway you towards Duet3 is that expansion boards don't have to be close to the main board like the Duet2/Duex combinations do. So that might simplify the wiring. But again, the list of limitations regarding motor/end stop/probe type/ board combinations might prevent you from putting the expansion board where you would ideally like it to be and/or wiring things in the neatest way. (Something else that I found out the hard way).
@dc42 said in Where's the Duet Wifi 3?:
No data on that spread sheet for the expansion boards with RC1. They were the most problematic for me with earlier firmware. Any idea what I might expect when doing firmware retraction simultaneously with 3 extruders per expansion board and two boards (so 6 extruders in total).?
Expect the same performance as for 3.2beta1, which is substantially better than for 3.1.0.
PS - today I finally found and fixed the cause of thermostatic fans blipping on expansion boards. The fix will be in the 3.2 release.
I'm glad about that. Although it was nothing more than a minor annoyance, I was beginning to doubt my own sanity, being that I seem to be the user who has noticed it.
I'm also waiting for the duet wifi 3. No interest what-so-ever in a raspberry pi for this application. KISS is gone out the window it seems. I want to upgrade my printers but until the duet wifi 3 is out there just isn't any point at all.
@minim said in Where's the Duet Wifi 3?:
Why exactly do you want to go with Duet3? What are the printer upgrades that you plan which will necessitate using Duet3 over the Duet2 ?
Since nobody answered it - @dc42 What's the forecast look like for the Wifi 2 in terms of availability, End of life announcement etc ? Or do you see the Wifi 2 as a staple in the Duet product line for the next several (<5?) years?
We have quite a number of OEMs using Duet WiFi and Duet Ethernet in their products, so we will continue manufacturing them as long as OEMs want them. But we expect new customers to gravitate towards the Duet 3 series.
There are also multiple suppliers in China producing their own clones (with varying levels of licence compliance).
As long as there is demand!
Just to pour some more fuel onto the angry fire...
Here's a nice little low cost device that can add wifi to an ethernet only device.
@Veti said in Where's the Duet Wifi 3?:
The speed of what is better because of the RPi?
the pi 4 has a 4x 1,8 ghz processor. it handles data transfer and processing in sbc mode
The only problem with an SBC it that for many users it doesnt work. even to the point of one user saying the following in another post ...
@NeueKlasse said in Duet 3 6HC Rev. 1.01 Faulty:
i am about to setup a TP-Link Nano and get rid of the Pi4...
And the forum has been littered with posts from users having SBC connection issues to the point where i could quote multiple times that the duet team has advised people to run the duet-3 in standalone mode.....
@Phaedrux said in Where's the Duet Wifi 3?:
S.M.H.
And that only supports what the op's point is, that to be able to use the duet 3 with a wireless capability you are FORCED to spend more be that by buying a SBC or a device you mention.
@CaLviNx Yes, and the demand for a wifi version is duly noted.
it might be noted, from experience it being acted upon is a whole different matter.........
@CaLviNx Merry Christmas Calvin. I do cherish our little chats. May the new year bring you peace and joy.
