Duet 3 + Tool Board Extruder/Retraction Issue
Another image
If you are running tool board firmware 3.1, then it could be that you are getting hiccups on the tool board (which you can check by doing a M122 report for the tool board). If that is the reason, then upgrading the tool board firmware to 3.2beta1 should fix it.
@dc42 said in Duet 3 + Tool Board Extruder/Retraction Issue:
It looks to me that it's retracting, but retracting too late in the game. this could explain the blobs at the end of the line and under retractions on the middle of line. Tool Board does reports hiccups constantly.
I will gladly upgrade the firmware to the latest beta if I can do it safely from the DWC. If it fails, I would most likely have issues with recovery.
Why so many blocked and suspended CAN bus messages?
Tasks: NETWORK(ready,1972) HEAT(blocked,1088) CanReceiv(suspended,3388) CanSender(suspended,1392) CanClock(blocked,1436)
In future can you copy and paste the text of the M122 rather than a screen shot?
@Phaedrux said in Duet 3 + Tool Board Extruder/Retraction Issue:
Sorry, here we go.
10/17/2020, 10:50:39 AM M122 B121 Diagnostics for board 121: Board TOOL1LC firmware 3.1.0 (2020-05-15b1) Never used RAM 8.4Kb, max stack 684b HEAT 640 CanAsync 1392 CanRecv 1380 TMC 156 AIN 524 MAIN 2284 Last reset 96:28:07 ago, cause: software Driver 0: open-load-A open-load-B, SG min/max 0/16, read errors 0, write errors 0, ifcount 54, reads 47102, writes 0, timeouts 0, DMA errors 0, failedOp 0xff Moves scheduled 3079196, completed 3079194, hiccups 7539 VIN: 24.0V MCU temperature: min 44.0C, current 56.2C, max 65.1C Ticks since heat task active 66, ADC conversions started 347266771, completed 347266770, timed out 0 Last sensors broadcast 00000002 found 1 69 ticks ago Free CAN buffers: 36 NVM user row b1d088a9 fffff8bb 20002a18 b TSENS 001602 GAIN 014ffc OFFS 00273f CAL 1f2a 10/17/2020, 10:50:30 AM M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956L2-G43S8-6JKDL-3SJ6L-1802G Used output buffers: 1 of 40 (22 max) === RTOS === Static ram: 154604 Dynamic ram: 162928 of which 140 recycled Exception stack ram used: 552 Never used ram: 74992 Tasks: NETWORK(ready,1972) HEAT(blocked,1088) CanReceiv(suspended,3388) CanSender(suspended,1392) CanClock(blocked,1436) TMC(blocked,60) MAIN(running,2672) IDLE(ready,76) Owned mutexes: === Platform === Last reset 96:27:46 ago, cause: software Last software reset at 2020-10-13 15:22, reason: User, spinning module LinuxInterface, available RAM 75056 bytes (slot 1) Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 43.3, current 44.6, max 45.6 Supply voltage: min 23.7, current 23.8, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Driver 0: ok, reads 59467, writes 0 timeouts 0, SG min/max 0/1023 Driver 1: ok, reads 59467, writes 0 timeouts 0, SG min/max 0/1023 Driver 2: ok, reads 59467, writes 0 timeouts 0, SG min/max 0/1023 Driver 3: ok, reads 59467, writes 0 timeouts 0, SG min/max 0/1023 Driver 4: ok, reads 59467, writes 0 timeouts 0, SG min/max 0/1023 Driver 5: ok, reads 59468, writes 0 timeouts 0, SG min/max 0/242 Date/time: 2020-10-17 15:50:17 Slowest loop: 20.33ms; fastest: 0.21ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 368, MinFreeDm: 336, MaxWait: 0ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves: 1176142, completed moves: 1176118, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.2 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 1 Movement lock held by null HTTP* is ready with "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is doing "G1 X202.007996 Y218.643997 E6.881300" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.72ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 1170785, longest wait 9ms for type 6024 === Linux interface === State: 0, failed transfers: 0 Last transfer: 20ms ago RX/TX seq numbers: 52239/52241 SPI underruns 0, overruns 0 Number of disconnects: 0 Buffer RX/TX: 1632/3096-0 === Duet Control Server === Duet Control Server v3.1.1 File: Buffered code: G1 X202.008 Y218.644 E6.8813 Buffered code: G1 X200.366 Y221.101 E6.9796 Buffered code: G1 X198.832 Y223.628 E7.0779 Buffered code: G1 X197.411 Y226.220 E7.1762 Buffered code: G1 X196.104 Y228.870 E7.2746 Buffered code: G1 X194.913 Y231.576 E7.3729 Buffered code: G1 X193.842 Y234.330 E7.4712 Buffered code: G1 X192.892 Y237.129 E7.5695 Buffered code: G1 X192.065 Y239.967 E7.6678 Buffered code: G1 X191.483 Y242.343 E7.7491 Buffered code: G1 X191.362 Y242.838 E7.7661 Buffered code: G1 X190.786 Y245.736 E7.8644 Buffered code: G1 X190.336 Y248.658 E7.9627 Buffered code: G1 X190.014 Y251.596 E8.0610 Buffered code: G1 X189.821 Y254.545 E8.1593 Buffered code: G1 X189.756 Y257.500 E8.2576 Buffered code: G1 X189.821 Y260.455 E8.3559 Buffered code: G1 X190.014 Y263.404 E8.4542 Buffered code: G1 X190.281 Y265.836 E8.5356 Buffered code: G1 X190.336 Y266.342 E8.5525 Buffered code: G1 X190.786 Y269.264 E8.6508 Buffered code: G1 X191.362 Y272.162 E8.7491 Buffered code: G1 X192.065 Y275.033 E8.8474 Buffered code: G1 X192.892 Y277.871 E8.9457 Buffered code: G1 X193.842 Y280.670 E9.0440 Buffered code: G1 X194.913 Y283.424 E9.1423 Buffered code: G1 X196.104 Y286.130 E9.2407 Buffered code: G1 X197.411 Y288.781 E9.3390 Buffered code: G1 X198.832 Y291.372 E9.4373 Buffered code: G1 X200.101 Y293.463 E9.5186 Buffered code: G1 X200.366 Y293.899 E9.5356 Buffered code: G1 X202.008 Y296.356 E9.6339 ==> 1524 bytes Code buffer space: 1588 Configured SPI speed: 8000000 Hz Full transfers per second: 32.49 File /opt/dsf/sd/gcodes/Pineapple_Bottom120_percent.gcode is selected, processing
@evomotors said in Duet 3 + Tool Board Extruder/Retraction Issue:
hiccups 7539
So you are getting a lot of hiccups on the tool board, so perhaps try the new beta?
is 7mm/s correct for your retraction speed?
hiccups 7539
Retraction speed is 7 mm/s, any value higher that that was performing extremely worst when stepper connected to the tool board.
I didn't install beta yet. I'm willing to do so, but a little confused in the instructions for installing unstable version using SBC and DWC.
What about bunch of blocked and suspended CAN bus commands on the Duet3 board itself?:
CanReceiv(suspended,3388) CanSender(suspended,1392) CanClock(blocked,1436) -
CanReceiv(suspended,3388) CanSender(suspended,1392) CanClock(blocked,1436)Those do not refer to messages. The clue is the "Tasks:" label at the start of the line.
Can you please point me to how to update to latest beta? What files do I need to download update DWC (looks like it's required for new beta) what bin files do I need to update Duet3 and tool board?
I'm looking at this guide right now:
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_from_RRF3_0_Beta_12_to_3_0_Final_via_DWC -
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_from_RRF3_0_Beta_12_to_3_0_Final_via_DWCThis is for a specific case for updating to 3.0 final from 3.0 beta 12.
To update to the 3.2 beta2 using a SBC you can add the unstable repository on the pi and then use sudo apt update sudo apt upgrade as usual.
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
@evomotors
Do you still face the same issue in extrusion ?
I'm planning to drive extruder from other board too. -
@user3d I believe all tool board extrusion issues are solved in recent firmware, though the firmware version must match between mainboard and toolboard.
@phaedrux said in Duet 3 + Tool Board Extruder/Retraction Issue:
Not toolboard. I'm planning so with EXP1XD
@phaedrux is it recommended? -
@user3d I am not aware of any issues using a EXP1XD to drive an extruder. The EXP1XD and the TOOL1LC use common source code, so the issues we fixed for the tool board are also fixed for the EXP1XD.
@dc42 ok. Thank you
