Noctua fan RPM Crazy number's
3 wire fan, 4 wire fan?
sorry i missed that is 4 wire
i have 3 fan's connected to one fan output but only from one tacho wire.
also i just found that when i put mouse over symbol for FAN RPM write Fan0
Can you provide the results of M115 please?
Do you have the fan wires running in the same bundle as the wires to a stepper motor?
30kHz is outside Noctua's spec for the PWM - it's nominal 25 kHz, and Noctuas documentation says "acceptable range 21kHz to 28kHz". I admit, however, that I'd expect 30kHz to work.
Hello
i will provide M115 results just that i will be home
no in bundle is no wire's for stepper motor noctua in same bundle is just power for water pumpand 30kHz or 25kHz what i had before set in no different
M950 F1 C"!duex.fan7+exp.pb6" Q30000
Try this instead, note the added ^ character:
M950 F1 C"!duex.fan7+^exp.pb6" Q25000
If that doesn't work then I suggest you try connecting a pullup resistor of between 1K and 5K between pin exp.pb6 and +3.3V.
@dc42 Thanks i will try
i try all change code, add pullup resistor i remove wire from bundel change all just that show Fan0 where i place mouse over Fan RPM instead of fan7
@matej1006 said in Noctua fan RPM Crazy number's:
I'm sorry, I don't understand - please explain what you mean.
that why is Fan0if i have Fan0 for colling filament
