0.8.5 firmware upgrade
I have a mini kossel with a duet 0.8.5 running firmware v 1.21RC1 (2018-01-25)
and web interface HTML: 1.11, JS: 1.11can I upgrade this to the latest firmware?
the latest firmware for the duet 0.8.5 is 1.26.1 found here https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1
The latest DWC for that board is 1.22.5 found here https://github.com/Duet3D/DuetWebControl/releases/tag/1.22.5 -
You might find this post helpful.
https://forum.duet3d.com/topic/16356/a-total-minefield-for-a-newbie?_=1601491424942
Thanks for replies, will have a look tomorrow.
@jay_s_uk said in 0.8.5 firmware upgrade:
Almost - the latest DWC is 1.22.6.
This post is deleted! -
I uploaded the file Duet2Firmware-2.05.1 onto the sd card and did a uprade. However now I cant connect to the duet and the panel 1 says conecting at the top of the screen in red but doesnt connect. Also if I go to device manager the port (was com 3) isnt listed.
So it seems the upgrade hasnt worked.
How can I recover this? -
If I erase the firmware the port 4 comes up. I can the connect via Bossa. I have tried uploading Duet2Firmware-2.05.1 onto the duet and verifying using bossa which verifes correctly. However I still cant connect via web control and Panel one still says connecting. Also com port 4 dissapears off device manager.
I think the firmware version is the wrong one, but cant find ver 1.26.1 only Duet2Firmware-2.05.1. Can someone confirm if this is the correct one.
Do I need to update web control software also? -
Finally got it sorted. Used RepRapFirmware.bin which seems to have loaded correctly.
@Dave-Parry said in 0.8.5 firmware upgrade:
That's the correct firmware file for 0.6 and 0.8.5 Duets, as it always has been.
