Unsolved Obey hard limit switches?
Hi All,
I'm back on this problem after smashing another 2 Z limit switches on the weekend, while hooking up a tool height probe.
Is there a way to hook up the limit switch - either to the switch pins or to other IO pins whereby I can prevent further travel in that direction of that axis only, without interfering with the program running (i.e. I don't want to hook it up to an E-stop).
There's no good reason why the machine should crash and for CNC machines there's no reliable way to define the working envelope without using end stops.
What are other people doing? I can't be the only person with this problem...Cheers
@Gerrard said in Obey hard limit switches?:
I'm not sure why you don't want to use an e-stop input. Can you explain?
And when you mention interfering with the program running what do you mean? How can you stop movement without interfering in some way?
I don't wan't to E-stop on a travel limit for a few reasons - Keeping in mind this is a CNC application:
Z up travel limit can easily be trivial - i.e. user has defined a tool lift of 20mm between moves, which works fine on some jobs, but others (different Z=0 height) it might be too much - and I would need to adjust my programming to compensate - whereas if the Z limit switch just stopped FURTHER travel it would continue the program without error. Soft limits (work boundary) already has this effect.
E-stop causes the home (G10) position to be lost.
What I expect is either:
- Replicate the effect of the soft limits - i.e. continue with program, no further movement in that axis until coordinates come back within limits. (This also has negative effects, but it's a lesser impact).
- Pause program completely (stop in place - do not use pause.g) wait for operator input
Ignoring the endstop (current practice) is the worst possible action.
Thanks for the feedback. I think I understand.
A couple of thoughts.
End stop inputs don't do anything special unless they are configured to do so.
Inputs can be configured to run specific chunks of code called triggers. Have you investigated them?
Thanks for the reply.
- How can I configure end stops to do what I want? What are my options for configuring?
- I haven't looked into triggers, but I will.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_Configure_external_trigger
Because RRF is configured on the fly you can define a piece of hardware at the time of usage. So in your homing files you can define the endstops as endstops, and then your G1 H1 moves will trigger the endstop and set the axis position limits. Then you can configure the endstops as triggers at the start of the job. The trigger could be an e stop, or it could execute whatever gcode you want to put in the trigger file. You could pause the job, for instance.
OK, thanks for that, I think we're getting somewhere... If I'm reading this right, there are 32 available triggers on the Duet3, the event that occurs is defined in a gcode file - triggerX.g (X for trigger number) and it's called by the T parameter of M581.
So that takes care of the triggers during jobs, but what about other Macros or manual movement (jogging etc)? Is there an overriding default behaviour? Should it be defined as a trigger in config.g, then configured as an endstop for the homing operations and a trigger again after homing?
Since it's configure on the fly, the last configuration will stand, so it's probably best to have the endstops defined in config.g as you normally would. Then in your homing files define them again as endstops for homing, since you don't know exactly what state might be in place before homing. Then if you want it defined as triggers before a job, you can use the macro file start.g which gets run before a job starts.
personnally here is what i do and i use G54 and G55
I have an end stop to the max Z height, i use it to home Z
i also have a simple probe
i use it with G31 so when the prob is done i have the z position of the tip of my endmill from the spoil board.after that what i do is a G0 Z67 F400 H3 (z67 is my maximum z height)
so the z carriage will go up trigger the zstop and replace the actual z value as z limitand about the G54 G55, what i do is i always configure my origine point as teh bottom left down point of either my stock or my object in fusion 360
then on my cnc i go in X and Y to what i want to be the 0,0 position (d'ont care about the Z as i allways know my hieght from the spoil board) then i do
G10 L20 P2 X0 Y0
G54
go to my tool change position perform the tool change it's a manual one) then do the z probe as explained earlier
do a G55 and go to 0,0
and start the milling operationsthe only thing i have to do is to reset the z limit height at 67 at the end and do a zhome and a G54.
i knwo there is a lot oof redundancy with G54 G55 then G54 without doing anything but my code is generated by a post processor.
G90 G21 M84 S0 M451 ;Switching to G54 workspace G54 M291 P"using current X and Y coordinates as X0 and Y0 for G55 workspace" R"XY origins" S3 X1 Y1 Z1 G54 ;Saving machine coordinates to slot 0, use G0 R0 X0 Y0 to return G60 S0 ;using current X and Y coordinates as X0 and Y0 for G55 workspace G10 L20 P2 X0 Y0 ;Switching to G55 workspace G55 G54 G28 Z10 G0 Z67 F400 G0 X550 Y30 F10000 M291 P"Tool 24 D=2 CR=0 " R"Tool change" S3 X1 Y1 Z1 ; COMMAND_TOOL_MEASURE M291 P"Attach ZProbe" R"Probe" S3 ;Switching to G54 workspace G54 ;Z probe at current position G30 ;Switching to G55 workspace G55 G0 Z67 F400 H3 M400 M291 P"Detach ZProbe" R"Probe" S3 ;Returning to S0 position G0 R0 X0 Y0 F10000 M114 ;Switching to G55 workspace ; *** START end ***
@Phaedrux
For the life of me I can't understand why end-stops would be ignored EVER.On a 3D printer reaching an endstop simply means that maybe some steps were skipped and you get a bad print. Not a big problem. On a CNC subtractive machine when you reach an endstop things break. Heaven forbid that you have a carbide tool running an 24000 RPM and it goes past an endstop. When that happens stuff goes flying at projectile speeds. Someone is going to get seriously hurt.
Honestly, telling a customer that they need to write their own macros to make end-stops function the way that every other CNC motion controller works already is not right. I think you should REALLY think about limiting your liability and include the capability to use hardware end-stops ALL THE TIME. As your product is applied more and more in the CNC realm your solution needs to keep up.
@maxspongebob I made a small tweak to the firmware to add a support for my own M113 command -- I tested it and using a trigger option when an endstop is triggered, the command runs and the duet stops immediately and reboots -- exactly how mach3 handles this condition. Yes I don't understand why there is no such similar behavior in duet by default, and I totally don't understand why have have hard limit switches if the machine is allowed to blow past them, CNC or 3D printer, but my solution is 4 lines of code in the firmware and a few lines in gcode scripts.
To be honest -- I thought this was baked in by default. I was sorta confused when I started doing my mill cnc conversion using duet 3 to find that there is no way to even do it. There is actually no way. If you setup a eStop trigger you have to reset or powercycle the board, no good. My custom M113 does exactly what eStop button in the webui / panel due does-- stop the world (immediately) and reboot. Works perfectly -
@maxspongebob I'm not saying this is how it should be, I'm simply explaining how it is currently. Having the option to obey endstops at all times when in CNC mode may be possible and is a valid firmware request. I'll raise that.
You can also make a thread in the firmware wishlist forum explaining how and why you think it should work if you want.
You can configure a trigger to be active only when running a job from SD card.
@kazolar said in Obey hard limit switches?:
Would it be better if emergency stop (M112) rebooted the board automatically?
The disadvantage i can see with doing that is that if the board is being fed GCodes via USB or from an attached SBC, it may start executing commands again immediately. I think that's why M122 was defined originally to require a manual reset. Similar how a proper Emergency Stop switch has be reset before you can run the machine again.
In my travels I have come across M564. Would a M564 H1 S1 at the start of my print, or just after the first layer keep the motion within the end-stops?
No, but if you set your maximum travel range the firmware will stay within that regardless of end stops. So if your motion system is dimensioned to not skip steps you'll be fine.
Otherwise add the macro to pause or e-stop if end stops are tripped.
@dc42 In answer you your question, I believe that a E-Stop signal should just stop all motion. It should not reboot the board as that would clear any of the events or activity that caused the problem and hamper investigation of the cause. On a CNC machine the E-Stop should also turn off the power to the servo's and spindle. That is unless they are equipped with a braking mechanism and in that case the brake should be applied first then power off.
The point is SAFETY. E-Stop is what you press if a problem exists that is going to cause damage to you or the machine. The stop or feed hold button is what you press if you think there may be a problem.
@maxspongebob said in Obey hard limit switches?:
Thanks. I guess we'll need a separate mechanism to reset the E-stop without resetting the board, possibly M999 S0 or else a new M-code.
