Thermistor daughterboard beginner question.
@sd_matt said in Thermistor daughterboard beginner question.:
d the daughterboard and the reading is still the same. I tried putting in a 100ohm resistor in the circuit and then just the resistor in place of the wires. Not sure what is going on. I am just beginning to try to understand the g code.
Are you sure ur not talking about the pt100 daughter board, you cant use a thermistor with it.
@davidvh86
"PT100 RTD Board Revision 1.1a By Duet 3d CERN OHL 1.2"Read right off the board
@bearer Im not sure if Im correct on the config as someone else walked me through it.
This post is deleted! -
now if we only had a picture to show where the board is connected and how the sensor is wired we could correlate it to the config.
but as it seems that is too much to ask I'm afraid we're at the end of what we can assist you with.
@bearer said in Thermistor daughterboard beginner question.:
" ; configure sensor 1 as thermocouple via CS pin spi.cs1
that is for firmware 3.x OP is using 2.02(RTOS) (2018-12-2
Oh sorry deleted it to avoid confusion lol
[deleted]
@dc42 What info are you missing. I can re post
@davidvh86 Is there anything you want me to post to clear up any confusion?
Post a photo of the sensor and the board.
@Phaedrux
@Phaedrux With the wire, or a 100 ohm resistor, or simply with the "daughterboard" removed I get the same result.......2000 and fault
Use the 100 ohm resistor. A wire will give you a 2000 reading.
If you send the M305 P3 X201 command from the console, does it respond with an error message?
What is the response if you send M305 P3 X200?
That is a thermistor, not a PT100 sensor.
Either connect the thermistor directly to the thermistor inout on the Duet board, or get a PT100 sensor like this to use with the daughterboard.
@dc42 said in Thermistor daughterboard beginner question.:
What is the response if you send M305 P3 X200?If you send the M305 P3 X201 command from the console, does it respond with an error message?
NoWhat is the response if you send M305 P3 X200?
M305 P3 X200
Error: Failed to initialise RTD: bad response from sensor -
@Phaedrux Ordered the part
