Magnetic Filament Sensor
@dm86 I might be wrong, but it could be that the way you've mounted the sensor is giving you issues?
Ideally you want the sensor to be as close as possible to your extruder. I'm not sure how long your feedtube is but if there is any slack in the filament path between the MFM and extruder, you're gonna get problems, particularly on segments of a print with lots of retractions (is this the case?). Also, what size is the PTFE tube and is it securely fixed at both ends with collet clips? If it's slightly oversized (even 2.0mm ID) the filament can kink up in the tube. This is essentially the same issue with Bowden setups. As it kinks and un-kinks during retract/un-retract, the extruder will be moving filament, but the sensor won't seen anything (hence is tripping).
If you're monitoring every 3.0mm of filament extruded, that's a comparable length to normal retraction (and also only a very small amount of plastic!). Have two retractions back-to-back with any flex/play/backlash in the feedtube between the extruder and MFM, and you're likely to set it off. When you tried it monitoring over 30.0mm of extruded filament, you'll average these issues out because overall the extruder and sensor are both working and the same total length of filament is travelling through both. The measured sensitivity is also quite different between the two results. I'm guessing this is from the same issue.
FYI I have a bowden setup with the MFM mounted ~30mm before the extruder. I've used Capricorn XS PTFE tube (1.9mm ID) and it's fixed at both ends with collet clips. My extruder is a Bondtech so the filament path is well constrained, even on the input-side. Even with all this, I can't go below ~5.0mm check lengths and have widened the allowance to 140/60% to avoid it occasionally tripping. It is the nature of these sensors that you have to take all of this into account when mounting and setting them up. In reality, having a slightly larger check window isn't a massive issue - it will still flag a filament-out
@engikeneer Thanks for the input. It's definitely not that, there is very little to no slack in the tube and being direct drive its pulled through keep it tight anyway. When it stops reading it stops for a while. Even setting to 100mm distance I'm getting 0% failures.
Having read more on some other posts it seems like my mag and agc values are too high. However I'm not sure what I can do about these and what they really mean? Hoping to get someone in the know to advise if I should be taking it apart or returning it?
@dm86 Would you be able to upgrade to RRF3? Specifically to 3.1.1. DC42 is in the process of investigating the magnetic filament monitors as part of the next update 3.2. So any testing we can do there would be beneficial.
@Phaedrux Should be able to. On a 5 day print so might take me a while to get to it. Although if I miss it running out of filament it might be a bit sooner
It does seem like a sensor issue though but I'll hold off taking it apart until after upgrading.
Well taking it apart and checking that things are aligned, etc is not a bad idea.
@dm86 said in Magnetic Filament Sensor:
I'm having difficulties get a new magnetic filament sensor working correctly. Most of the time it reads 'good' values of around 95-105% but will randomly drop right down to only a couple of percent or even 0.
Is it worth me taking the sensor apart? Is there anyway to tighten tolerances or anything? Being a new sensor should I just request a return (however reluctant due to international shipping. In UK but ordered from hobbystore.pl)
Have tried different measurement lengths from 3 up to 30mm
Not working.....
M591 D0 Duet3D magnetic filament monitor on input 3, disabled, sensitivity 24.80mm/rev, allow 70% to 130%, check every 3.0mm, version 3, mag 114 agc 128, measured sensitivity 35.60mm/rev, min 0% max 132% over 982.7mm
Your AGC value is too high and out of tolerance. Less than 100 is good. The usual reason is that the distance between the magnet (on the end of the rotating shaft) and the sensor is too great. Suggestions:
- Check that the 3 screws are tight (but don't over-tighten them, that may strip the threads)
- If that doesn't lead to a lower AGC value, then remove the two long screws to separate the two halves. Sand down the flat mating surface very slightly, then reassemble.
@dc42 Thank you both.
As its brand new I didn't want to take it apart and be accused of being the problem myself without checking here first.
Today it decided to start throwing errors and pausing the print even with the sensor disabled so wondering if there is something else going on too.
2020-06-22 13:15:32 Resume state saved 2020-06-22 13:15:32 Extruder 0 reports sensor not working 2020-06-22 13:15:35 Printing paused at X149.7 Y115.4 Z33.3 2020-06-22 14:52:37 HTTP client 192.168.50.130 login succeeded 2020-06-22 14:52:48 Printing resumed 2020-06-22 14:52:48 Resume state saved 2020-06-22 14:52:48 Extruder 0 reports sensor not working 2020-06-22 14:52:51 Printing paused at X149.7 Y115.4 Z33.3 2020-06-22 14:53:00 Printing resumed 2020-06-22 14:53:00 Resume state saved 2020-06-22 14:53:00 Extruder 0 reports sensor not working
When this print finishes will upgrade and recheck everything and report back.
Out of interest, what does mag and agc actually mean?
PS I realised I post in the wrong category, can an admin move to the sensor one? TIA
It was already moved.
'agc' is automatic gain control, used to bring the signal magnitude from the Hall sensor in range. The maximum value available is 128.
'mag' is the magnitude of the signal from the Hall sensor element, after applying agc. Under normal conditions, 'agc' will be in the range 85 to 105 and 'mag' won't change much. So 'mag' is less useful than 'agc'.
The fact that 'agc' is at maximum also explains why you get the 'sensor not working' report sometimes, because 'mag' will sometimes be too low for the sensor to work properly.
@dc42 Not much joy again today. Tightened down as all 3 screws were loose. 2 did clamp down a bit and I did see the seam close a little bit as I did it. However the third one was loose and turning it didn't seem to tighten it up at all.
M591 D0 Duet3D magnetic filament monitor on input 3, disabled, sensitivity 24.80mm/rev, allow 50% to 130%, check every 30.0mm, version 3, mag 129 agc 128, measured sensitivity 10770.89mm/rev, min 0% max 2898% over 1809.2mm
However that seems to have had no improvement at all. When this print finishes/fails I will try taking it apart and giving it a light sand. I appreciate its tight tolerances and all but not a great experience on a £60 sensor.
Out of interest when do the AGC/MAG values update? If I tweek the screws how can I read updated values? Run M591 after a few seconds of printing or does it need a reboot in-between?
@dm86, would you like the sensor replaced under warranty? I've never seen a sensor with an AGC reading at maximum.
When there is no filament motion, changes in AGC reading should be visible in M591 within a second or two. The red flashes of the LED on the filament monitor indicates that the monitor is sending status words, including the AGC value.
@dc42 I think that is my only option at this point.
I spent ages on it last night trying to tweak it in to life. I got a slight improvement on mag after sanding off a rough spot on the 'non-flat' side of the enclosure. But still only got it down to 112, AGC stayed maxed out.
I also tried it on my Duet2 just to check it wasnt something weird on my Maestro and got the same readings.
I originally purchased through Hobby Store PL. Do I need to return to them?
Thanks
@dc42 Can you advise how to get this exchanged please?
Contact them for a warranty replacement, reference this forum thread for evidence of warranty approval. In case it wasn't clear from @dc42's answer, we approve a warranty replacement. Sorry for the inconvenience.
So loads of hastle sending it back to Poland, which then got lost in the post. Credit to Hobby Store for having good customer service and sending me a replacement regardless. However, replacement even worse than the original. Also noticed last post in here a fault sensor also from Hobby-Store.
Whats going on here? Just a bad batch?
M591 D0 Duet3D magnetic filament monitor on input 3, enabled, sensitivity 24.80mm/rev, allow 40% to 130%, check every 20.0mm, version 3, mag 132 agc 120, measured sensitivity infmm/rev, min 0% max 0% over 11519.9mm
Bought a Duet 2 Wifi from E3D that end up being thrown in the bin because it didn't work, really starting to lose faith here. Unfortunately unlike Hobby Store, E3D's customer service is terrible so given up that fight.
OK I've taken it apart, checked it, light sanding on one side, tightened it all back down and no improvement on Mag & AGC values. Sensor works intermittently.
Please can someone advice whats going on and how to proceed please?
Hi, we will take another look. Thanks for you patience.
Have you gone through updating to 3.1.1 as we discussed earlier?
I have on my Duet 2 but I'm having wifi problems with that. I then had problems trying to upgrade my Maestro but as the printer is going nearly 24/7 haven't been able to solve that yet. Will try and take another look tomorrow.
I have tried it on both boards and Mag + Agc values report the same but I don't have working wifi on the Duet 2 I haven't been able to try much of a test print.
Sorry to hear you're having so many issues. Please allow for some time zone delay before DC42 has a chance to take a look.
@dm86 that agc value is high. please mail me, info@duet3d.com and we will work out how to proceed because we don't yet have the new housings needed for a direct replacement.
