Printing stop momentarily
Hi all, I have a problem with the head stopping for a second or so about every minute or less depending on the size of the object being printed. All my other printers are a fluid motion, this Duet2 WiFi one appears to be jerking and stopping and starting.
Any assistance would be greatly appreciated.
This is the Diagnostics log.
ThanksM122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L2MSD-6J9DJ-3S86L-TBD2N
Used output buffers: 3 of 24 (9 max)
Static ram: 30516
Dynamic ram: 92320 of which 0 recycled
Exception stack ram used: 560
Never used ram: 7676
Tasks: NETWORK(ready,648) HEAT(blocked,1240) MAIN(running,3676) IDLE(ready,156)
Owned mutexes:
Last reset 03:12:43 ago, cause: power up
Last software reset at 2020-06-16 21:09, reason: User, spinning module GCodes, available RAM 7724 bytes (slot 3)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 9
SD card longest block write time: 15.5ms, max retries 0
MCU temperature: min 34.7, current 60.6, max 61.2
Supply voltage: min 22.8, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: ok, SG min/max 0/196
Driver 1: ok, SG min/max 0/186
Driver 2: standstill, SG min/max 9/190
Driver 3: ok, SG min/max not available
Date/time: 2020-06-22 11:44:03
Slowest loop: 94.97ms; fastest: 0.09ms
Hiccups: 0(0), FreeDm: 139, MinFreeDm: 115, MaxWait: 680005ms
=== MainDDARing ===
Scheduled moves: 317506, completed moves: 317466, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
=== AuxDDARing ===
Heater 0 is on, I-accum = 0.0
Heater 1 is on, I-accum = 0.4
Segments left: 1
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is doing "G1 X145.982 Y198.556 E2.9964" in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 157.86ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address bc:dd:c2:57:ad:c0
WiFi Vcc 3.34, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 26104
WiFi IP address 192.168.1.101
WiFi signal strength -70dBm, reconnections 0, sleep mode modem
- WiFi -
Post your config.g and config-override.g if you have one.
My Config.g
; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 31 2020 17:50:46 GMT+0700 (Indochina Time); General preferences
M550 P"NEW Raise N2" ; set printer name
M564 H0
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P4 S1 ; physical drive 4 goes forwards
M584 X0 Y1 Z2 E3:4 ; set drive mapping
M92 X80.00 Y80.00 Z800.00 E415.00:415.00 ; set steps per mm
M566 X900.00 Y900.00 Z22.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z280.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z40.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E700:700 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S10 ; Set idle timeout; Axis Limits
M208 X300 Y300 Z300 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T9000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"pt1000" R4700 ; configure sensor 0 as PT1000 on pin bedtemp
M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
M143 H1 S280
M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as thermocouple via CS pin spi.cs2
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M143 H2 S280 ; set temperature limit for heater 2 to 280C
M501; Fans
M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 S"HOTEND1" D0 H1 F0:1 ; define tool 0
M221 S100 D1
M563 P1 S"HOTEND2" D1 H2 F0:1 ; define tool 1
;M563 P2 S"HOT2" D1 H2 F0:1 ; define tool 2
;G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
;G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C; Custom settings are not defined
M501 -
My config-override.g
; config-override.g file generated in response to M500 at 2020-04-20 11:32
; Heater model parameters
M307 H0 A97.1 C417.0 D1.8 S1.00 V23.2 B0
M307 H1 A394.1 C133.8 D6.7 S1.00 V23.9 B0
M307 H2 A282.8 C108.3 D6.7 S1.00 V24.0 B0
; Workplace coordinates
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00 -
@Rattlemycage are you using bed mesh compensation and if so, how smooth/flat is your mesh?
You might be having the same problem as this: https://forum.duet3d.com/topic/17122/jumpy-x-y-movement-on-maestro
Your Z Jerk and Accel are quite low (note the Jerk units are mm/min, not mm/s!) so might be affecting X/Y movement if the bed can't keep up with the mesh compensation. lf this is the case, fixing the bed/the height map is also a good idea
I am not using using bed mesh compensation. What speeds do you suggest i take my Z Jerk and Accel ?
More so how do I alter it?
Thank you.
@Rattlemycage if you are not using bed mesh compensation, it could also be that you have your slicer set to 'Lift Z' on a retract?
My Zaxis settings are: 75 mm/min Jerk & 200 mm/s^2 accel
I have 3 Z-motors wired in series to the Duet so can't run them very hard/fast - they used to be faster/higher accel/Jerk when I only had 2 Z-motors. When setting these, I just kept adjusting the numbers whilst moving the Z axis up and down ~20mm until I found the limit where the Z- motors would start skipping steps. I then set my Jerk/Accel to be a bit less than that to be on the safe side.
Other thought, It could equally be your extruder motor settings causing slow retractions (exactly as with the Z-axis) as these look a little low (depending on your setup). Try increasing the extruder Jerk and Accel settings and see if that helps.
On either of these, your motor currents are all set at 800mA. Not sure what your motors are (so check what their limits are!) but you could go higher to get more torque and so allow higher accel and jerk values.
For all of these, just update the numbers in right lines the config.g file via Duet Web Control, save it and reboot the Duet. Whilst tuning, you can temporarily tweak them by sending the relevant comands via the G-code command line in DWC
Thank you so much for your assistance.
@Rattlemycage said in Printing stop momentarily:
M201 X500.00 Y500.00 Z40.00 E250.00:250.00 ; set accelerations (mm/s^2)These are the lines you would edit by the way.
Also, what slicer are you using? Could you share a video of the behaviour?
Are you printing the file from the built-in SD card, or some other way (e.g. via USB or an external SD card)?
I am printing the file via the Duet Web Control 2.0.4
The slicer is Simplify3D.
When the head stops it leaves small blobs of filament.
I increased the speed. without success. Still stopping. What am I missing guys?
M566 X900.00 Y900.00 Z200.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z2000.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z250.00 E250.00:250.00 ; set accelerations (mm/s^2)
@Rattlemycage Does this momentary stopping coincide with a layer change, or with a retraction, or is it seemingly random? Can you make and post a video of it happening?
@Rattlemycage, It is seemly random. On a single layer of an object perimeter, say 4 inches by 5, it might actually come to a stop 7 or more times. I tried to upload a video but my files are larger than the 4mb permitted.
For larger files you will need to host them on a file sharing cloud platform like dropbox or google drive or vimeo or youtube.
Can you also share the sliced gcode file itself?
Your E speeds are still quite slow at 1200mm/min. That would restrict your retraction speed to 20mm/s. If you have a longer retraction move that can lead to a noticeable pause at travels and layer changes.
A low E jerk can also cause slow downs when used with pressure advance, but I don't see pressure advance command in your config.
I would suggest trying these speeds
M566 X900 Y900 Z200 E3000:3000 ; set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z2000 E6000:6000 ; set maximum speeds (mm/min) M201 X2000 Y2000 Z250 E3000:3000 ; set accelerations (mm/s^2) M204 P500 T2000 ; print and travel move acceleration
I've removed the .00 to make it more legible. And added the M204 command to have seperate print and travel move accelerations which should speed up travel moves quite a bit which can help blobbing as well. (assuming the blobbing is on retractions.)
Thank you for all your assistance. I feel rather embarrassed to ask for more.
I have the settings for my machine.Printing Acceleration 1000.00 mm/s2
Retract Acceleration 3000.00 mm/s2
Travel Acceleration 1000.00 mm/s2
Max Acceleration X 9000.00 mm/s2
Max Acceleration Y 9000.00 mm/s2
Max Acceleration Z 100.00 mm/s2
Max Acceleration E 10000.00 mm/s2
Max Jerk X/Y 12.00 mm/s
Max Jerk Z 0.40 mm/s
Max jerk E 5.00 mm/sHow do i put these values in my config.g please?
Thank you
Well you must first edit the config.g file either on the web interface or on the SD card directly.
https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual
The values you want to edit are the ones I pasted above. Bear in mind that the values you posted are from marlin and are in mm/s and RRF uses mm/min, so note the units being used.
I would still recommend the values I posted.
