Using a 4th (Rotary) Axis
Just define it as a normal additional axes, but swap mm for degrees in all the configuration commands e.g. M92, M201, M203, M208, M566.
@dc42 Thanks for the response. I'll have to be cautious with absolute and incremental movements in that case. Without a direction parameter there are always 2 ways to get to a position.
With absolute positioning, if for example towards the end of carving a thread around a dowel with 10 turns, you would end up getting to 3600 degrees, returning to 0 from that position would mean unnecessarily 'unwinding' the axis. A modulus function in meta commands would easily allow you to find the nearest 0 degree point again I suppose. It's just going to be case of wrapping my head round something new.
Having had a very short play with machining outputs from fusion I found that using the Fanuc post processor was outputting I and J parameters so I assumed they were similar to G2/3 but their was no G parameter at all and other post processors were completely different. Still havent gone very in depth with it yet. Lots to investigate and experiment with.
@littlehobbyshop said in Using a 4th (Rotary) Axis:
This is true. The firmware has the means to handle rotary axes differently (it's used on polar and some SCARA machines), but currently there is no command to declare that an axis is rotary.
@littlehobbyshop please pass along your experience going forward. I occasionally add a 4th axis (currently just for indexing) to my Duet controlled micro mill. https://forum.duet3d.com/topic/11581/duet-controlled-micro-mill My CAM outputs 4th axis though I have yet to dedicate the time to explore simultaneous work. My current focus is an ATC for the machine but plan to start working again on the the "A" axis soon after that is complete
@dc42 Hi David, I am trying to get in contact with you concerning SCARA.
I have posted a link on the forum , can you please have a look at it, I need your opinion.
Thank youhere is the link
https://forum.duet3d.com/topic/14114/scara-robot-want-to-know-if-duet-wifi-is-the-right-choice?_=1580465871679 -
I know you want an answer from dave... but... as @Phaedrux said in the other tread, Duet WiFi will definitely drive the scara geometry you show.
Here is how to configure it:
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareSCARAPrinter
I’m kinda at a loss it may be old age or ignorance , how would one define the U axis (Rotary) to degrees instead of mm on a Cartesian CNC for M92 201 203 etc . Preferably to be a free axis with no limit switch .
@tntjet said in Using a 4th (Rotary) Axis:
you sort of don't; i.e. the axis doesn't actually know about units - so just set the steps/mm to whatever steps you need to turn to move 1 degree instead of 1mm.
Ok I see, that’s what I was missing , my axis has 600 steps per 360. 1.6666 per degree ?
@tntjet yes, if you have taken the microstepping into account, if not make sure to do that as well.
E.g. if its 600 full steps and you use 16x microstepping (with or without interpolation to 265) its 600 x 16 / 360 = 26.6666.
Thank you so much @ bearer , you have made my evening.
is it possible to make this axis continuous in the M208?
ref https://forum.duet3d.com/topic/16788/u-axis-without-limit/12 (i.e. not yet faik)
Legendary ! Thanks again.
