Fan short circuit, how to fix?
Thanks!
Indeed, I've found the fuse. it is broken...
unfortunately it is not a common fuse... I've check in auto store and the mini fuse start at 3AI would have to order online and wait weeks
@carfnann said in Fan short circuit, how to fix?:
while its probably not supported both the fan mosfet and the traces* on the board can deal with 3A, so in theory the the fuse (or the fan wiring) should fail before the board if you were to use a 3A fuse while you wait, and a fault develops. On the other hand odds are the mosfet for the fan in question is also blown, so I'd probably use a 3A just to test even if not for prints.
*) according to https://www.4pcb.com/trace-width-calculator.html
edit: if you find somewhere that fix motorcycles, they might have 1A fuse
feeling @carfnann's pain as I'm trying to find the same fuse! Easy to finds 3A+ (even 2A on Amazon), but 1A not so.
Hoping mine will just be the fuse and not the mosfet as I wasn't playing with it and short it (what's more, since I've had the Duet wifi... it's never had a fan plugged into it!
Where about is that guy out of interest?e_p
@en_passant said in Fan short circuit, how to fix?:
if the short circuit curren't didn't pass through the mosfet then its probably okay, the other way around the mosfet usally fail before the fuse.
sharing OPs general location might be a good idea, myself and others may also have a fuse to spare nearby.
@bearer said in Fan short circuit, how to fix?:
If you should happen to find another, I know someone in London who'd be grateful!
e_p
@en_passant That very weird, I was able to easily find a 1amp mini fuse on Amazon. I pretty much did the same thing as OP. Got a very nice spark. I was so freaked out that I may have fried my board or something. Then I Googled it and found out about the fuse. Checked it and sure enough, it was blown. Ordered new fuse, only could get it with 10 in a pack. lolz, I guess I have a few extra tries to see some sparks fly. J/K.
If you would like and it is not against the forum's rules, I could post you the link to what I bought to replace my fuse.
Please, yeah. (Not sure it's against forum rules, but don't think so...)
I've found 1 - but it's on eBay from China and going to take a month to arrive!
e_p
@en_passant Admins, please forgive me if I am breaking the rules by posting a link in your forum's. I am only doing this to help a fellow member out.
https://www.amazon.com/dp/B0721P1RNT/ref=cm_sw_r_em_apa_i_fx73EbT65D528
This is the type of fuse you will need. You can find them in lower quantities, but for $8.00 dollars, its not like they are that expensive.
Ahh, you're in the US. I did also find them - but I'm in the UK... which seems to have a distinct lack of 1A ATM mini blade fuses!
Might have to go with China....
e_p
@en_passant Hmm. Well that kinda stinks then. I will try and find it for you in the UK.
@en_passant Please try this link.
https://www.amazon.com/dp/B07N3YP4C1/ref=cm_sw_r_cp_awdb_t1_3J73EbWQ03GP8
It says they ship to UK and you can get it by this Friday
Posting links is fine.
@en_passant I am glad I was able to help soneone today. It makes the day worth living and enjoying.
You can find them in the UK here https://www.co-star.co.uk/3758/mini-blade-fuse-1amp-black-pack-of-10-fbm-1-10/.
They are usually available from UK eBay suppliers too, but they seem to be out of stock of the 1A version at present.
@dc42 Doesn't Duet3D stock them?
I was able to find one supplier of these mini fuse 1A on amazon.fr
order them a box, then they cancel my order because out of stock...no way to find some in France...
and today I've received my panel duet 7 and cannot play with it
@carfnann From https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Blade_fuses
PCB revisions 1.03 and later have a 1A mini auto blade fuse protecting the fan circuits when the fan voltage selection jumper is in the VIN position. You can increase the fuse rating to 2A or even 3A if your fans, air pumps etc. draw more than 1A in total.
It should be okay to fit up to 3A fuse temporarily, but please make sure you fit a 1A fuse when it becomes available. And turn off your machine before changing the wiring!
I purchased 10 from the link @dc42 supplied. I've checked and it shows they will post to outside UK but I don't know costs, see here:
I've also just fitted a 2A from this, until the 1A fuses arrive from the link above. May be worth looking at if they deliver to France or if there's an equivalent, if delivery from the other link may take some time.
I was slightly more concerned as to why the fuse blew but I've just fitted my E3D V6 fan and when I powered up it spun away so I'll switch that engineering side of my brain off for now.....
HTH,
e_p
