Fan short circuit, how to fix?
Hi
I was changing my heatsink fan and did a short circuit on the wire (with a nice spark)...
Board seems ok, I can Home All, launch heating on Tool and Bed but I have no fan working now...
I have 2 fan on Always On and 2 on Pwm fan.What can I do to fix my fan? is there a fuse to change?
Thanks
What board are you using?
oops sorry, I'm using a Duet 2 WiFi
If you have a v1.03 or newer, I think you have to replace a fuse. See https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams There is a blade fuse in the middle for the fans.
Thanks!
Indeed, I've found the fuse. it is broken...
unfortunately it is not a common fuse... I've check in auto store and the mini fuse start at 3AI would have to order online and wait weeks
@carfnann said in Fan short circuit, how to fix?:
while its probably not supported both the fan mosfet and the traces* on the board can deal with 3A, so in theory the the fuse (or the fan wiring) should fail before the board if you were to use a 3A fuse while you wait, and a fault develops. On the other hand odds are the mosfet for the fan in question is also blown, so I'd probably use a 3A just to test even if not for prints.
*) according to https://www.4pcb.com/trace-width-calculator.html
edit: if you find somewhere that fix motorcycles, they might have 1A fuse
feeling @carfnann's pain as I'm trying to find the same fuse! Easy to finds 3A+ (even 2A on Amazon), but 1A not so.
Hoping mine will just be the fuse and not the mosfet as I wasn't playing with it and short it (what's more, since I've had the Duet wifi... it's never had a fan plugged into it! )
Where about is that guy out of interest?e_p
@en_passant said in Fan short circuit, how to fix?:
if the short circuit curren't didn't pass through the mosfet then its probably okay, the other way around the mosfet usally fail before the fuse.
sharing OPs general location might be a good idea, myself and others may also have a fuse to spare nearby.
@bearer said in Fan short circuit, how to fix?:
If you should happen to find another, I know someone in London who'd be grateful!
e_p
@en_passant That very weird, I was able to easily find a 1amp mini fuse on Amazon. I pretty much did the same thing as OP. Got a very nice spark. I was so freaked out that I may have fried my board or something. Then I Googled it and found out about the fuse. Checked it and sure enough, it was blown. Ordered new fuse, only could get it with 10 in a pack. lolz, I guess I have a few extra tries to see some sparks fly. J/K.
If you would like and it is not against the forum's rules, I could post you the link to what I bought to replace my fuse.
Please, yeah. (Not sure it's against forum rules, but don't think so...)
I've found 1 - but it's on eBay from China and going to take a month to arrive!
e_p
@en_passant Admins, please forgive me if I am breaking the rules by posting a link in your forum's. I am only doing this to help a fellow member out.
https://www.amazon.com/dp/B0721P1RNT/ref=cm_sw_r_em_apa_i_fx73EbT65D528
This is the type of fuse you will need. You can find them in lower quantities, but for $8.00 dollars, its not like they are that expensive.
Ahh, you're in the US. I did also find them - but I'm in the UK... which seems to have a distinct lack of 1A ATM mini blade fuses!
Might have to go with China....
e_p
@en_passant Hmm. Well that kinda stinks then. I will try and find it for you in the UK.
@en_passant Please try this link.
https://www.amazon.com/dp/B07N3YP4C1/ref=cm_sw_r_cp_awdb_t1_3J73EbWQ03GP8
It says they ship to UK and you can get it by this Friday
Posting links is fine.
@en_passant I am glad I was able to help soneone today. It makes the day worth living and enjoying.
You can find them in the UK here https://www.co-star.co.uk/3758/mini-blade-fuse-1amp-black-pack-of-10-fbm-1-10/.
They are usually available from UK eBay suppliers too, but they seem to be out of stock of the 1A version at present.
