Invitation to share your conditional GCode scripts
We plan to document the object model when it has settled down, after the RRF 3.01 release.
move.calibration.initialDeviation is the deviation reported by probing. finalDeviation is the expected deviation after the firmware had made the corrections. Both are set to zero if no auto calibration/true bed levelling has been done
Hi, I've had a couple ideas which I think might only be achieved with conditional g-code.
- Save waste-board location along z axis to be used when setting work-coordinate Z0 location during known stationary probe. This would be a useful for CNC router machines.
- Work out vector angle from x and y axis coordinates to control 5th axis motor. This could be toggled on/off in the web interface, and useful in implementing a tangential knife cutter or large scale concrete extrusion.
- Using switch state to control warning light system on 3D printer or CNC machine. Un-homed could be yellow, cutting or extruding will show red, and idle could be a white light.
- Safety enclosure door behaviour during different machine states. More specific for CNC but if cutting, pause job and display message 'enclosure has been opened,' if not cutting ignore switch state.
I'm not sure what is possible yet as I've only just updated to RRF3.01 RC6 but these are the type of behaviours I am interested in. Cheers.
I did this one for calibrating the trigger height on a BL Touch
I tried a bunch of ways to store a fake variable, but nothing was easy enough to make this useful for a newbie, so for now you have to average the results.I'm not 100% sure homing first is the best way on a brand new machine, but it can be commented out or made conditional with another M291.
;Calibrate BL Touch trigger height ; When we get variables we can define one here ; Uncomment when ready to use ; var RunningTotal=0 ; var average=0 ; If the printer hasn't been homed, home it if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed G28 M564 S0 H0 ; Allow movement beyond limits if move.axes[2].machinePosition < 6 ; make sure we have probe clearance G1 Z6 M280 P0 S160 I1 ; reset BL Touch G4 S0.5 M98 P"0:/sys/retractprobe.g" ; Ensure probe is retracted & reset G4 S0.5 M290 R0 S0 ; clear any baby stepping M561 ; clear any bed transform ; Jog head to position M291 P"Jog nozzle to touch bed" R"Set nozzle to zero" S3 Z1 G92 Z0 M291 P"Press OK to begin" R"Ready?" S3; ; carry out 10 probes while iterations <= 9 G1 Z6 M400 if sensors.probes[0].value[0]=1000 ; if probe is in error state echo "Probe in error state- resetting" M280 P0 S160 I1 ; reset BL Touch G4 S0.5 M98 P"0:/sys/retractprobe.g" ; Ensure probe is retracted & reset G4 S0.5 G30 S-1 M400 ; Uncomment when variables allowed ; RunningTotal=RunningTotal + move.axes[2].machinePosition ;average=RunningTotal/(iterations+1) G4 S0.5 ; Until variables come use this M291 P"Check console for results and enter average value in G31 Z parameter of config.g" R"Finished" S3 ;When variables come uncomment this ;G31 Z{average} ;M291 P"Trigger height set to : " ^ sensors.probes[0].triggerHeight ^ " Press OK to save to config, cancel to use until restart" R"Finished" S2 ;M500 M564 S0 H1 ; Reset limits
I was looking for a Thermostatic Fan trigger and was pointed to a post about daemon.g. Based RRF3.1-RC9 + SBC I now have my fan control for my power tied in.
This conditional logic is really powerful.. thanks for all the hard work.
M98 P"0:/macros/Special Scripts/Check Power Supply" G4 S10 ; wait 10 seconds
if fans[3].actualValue > 0.0 && sensors.analog[3].lastReading < 25 ;echo "fan running and temp less than 25c... stop fan" M106 P3 S0.0 elif fans[3].actualValue < 0.5 && sensors.analog[3].lastReading > 35 ;echo "fan stopped and temp greater than 35c... start fan" M106 P3 S1.0
Another example using daemon.g
I'm in the process of adding some extra safety checks.
This will check the heater temps when idle and initiate action such as shutting off all power, activating an alarm (probably requires a latching relay)
As RRF checks this when printing there's no need to run this section of the code unless idle.; daemon.g ; check temps every 10 seconds when not printing (i.e. Idle) and shut down if exceed max temps. RRF checks when printing, but not when idle. ; not all commands are required. e.g. shutting off power by dropping a relay negates need for M112, M81 - un-comment or adjust as required for your configuration ; assumes that the thermistor for each heater is monitor # zero as there is no way to do nested loops using "iterations" as identifier in both loops until variables are available in the object model ; no checking done for null values! - if state.status="idle" while iterations < #heat.heaters ; ;if heat.heaters[iterations].current > heat.heaters[iterations].monitors[0].limit ; un-comment when ready to go live if heat.heaters[iterations].current > 50 ; uncomment for testing, comment out when going live M291 P"Heater over max temp" R"Temp Error!" S1 T0 ; Display message for testing ;M112 ; Do emergency stop ;M81 ; Turn PS_ON (ATX) off ;M42 P5 S1 ; Set GPIO 5 (output) high to activate alarm relay. GPIO pin must be configured using M950 ;M42 P6 S0 ; Set GPIO 6 (output) low to cut power. GPIO pin must be configured using M950 ;if sensors.gpIn[6].value=1 ; check state of connected smoke detector - GPIO pin must be configured using M950 ;M291 P"Smoke detector active!" R"I'm on fire!" S1 T0 ; Display Nikki Lauder message for testing ;M112 ; Do emergency stop ;M81 ; Turn PS_ON (ATX) off ;M42 P5 S1 ; Set GPIO 5 (output) high to activate alarm relay ;M42 P6 S0 ; Set GPIO 6 (output) low to cut power G4 S10 ; wait 10 seconds before next check (adjust S parameter as you see fit)
@OwenD Please can I make a suggestion, at the beginning, issue a
M290 R0 S0
to reset baby stepping before you try to start performing jogging Z and trigger heights.
Just this minute made that mistake!
Paul
@PaulHew said in Invitation to share your conditional GCode scripts:
M290 R0 S0
Paul
Good idea!
So let it be written... -
Code to check if all axes are homed and optionally home them, or cancel macro.
It iterates across ALL axes making it more portable code (for those with >3 axis)
This saves manually listing them in an if || (or) statement such asif !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
I imagine this would be useful for tool changing printers where you might be doing something that may or may not require homing.
For the rest of us, I'd just run G28 if any are not homed.;first check if any axes are not homed and optionally home them while iterations < #move.axes if !move.axes[iterations].homed ; check if each axis is homed M291 P{"Axis " ^ move.axes[iterations].letter ^ " is not homed. Home now?"} R"Axis un-homed" S3 ; continue or abort? M98 P{"0:/sys/home" ^ (move.axes[iterations].letter) ^ ".g"} ; home axis if answer is OK - G28 doesn't accept object variable so run macro ; rest of code here
Here is what I use to choose machine type at startup depending on what tool is connected.
I include a resistor connected to the sensor pin inside the tool connector. This gives a fixed temperature reading and lets the machine choose its type depending on what is connected at startup.M308 S23 P"e2temp" Y"thermistor" T100000 B3950 A"ModeSelector" ;setup a thermistor input as config selection sensor ;wait for the sensor to start returning meaningful values (don't know if there is a better approach for this) while sensors.analog[23].lastReading==0||sensors.analog[23].lastReading==2000 echo ;print the value detected (useful when adding a new mode) ;M117 ModeSelector value:{sensors.analog[23].lastReading} ;depending on sensor reading choose a system folder if sensors.analog[23].lastReading==-273.1 M117 No Attachment Detected. elif sensors.analog[23].lastReading<155 M117 Going to be a CNC. M505 P"CNC" else M117 Going to be a 3D printer. M505 P"Printer" ;load config.g from the chosen system folder M98 P"config.g"
That’s pretty cool. I’m considering my using a serial line with some tiny85 chips that I have laying around to do the same thing. For now I write out a script that I try to call from config.g that just sets up the last executed tool script.
M28 "0:/sys/lasttool.g" M98 P"0:/macros/Config Scripts/Setup 3 to 1 Hotend" M29
I have a script that uses conditional code to clear out tools, fans, and heaters as well as de-energizing my relays (stepper bank switch).
;echo "check temperature" while iterations < #sensors.analog if sensors.analog[iterations] != null && sensors.analog[iterations].lastReading > 32 && sensors.analog[iterations].name != "PS" if sensors.analog[iterations].name != "Bed" abort "Must wait for tool head to cool down!!!" ;echo "set relays" M18 E ; Turn off Steppers for extruders G4 P100 M42 P0 S0 ; Ensure relay 0 is off M42 P1 S0 ; Ensure relay 1 is off M42 P2 S0 ; Ensure relay 2 is off G4 P100 ;echo "remove all tools" while iterations < #tools ;echo "Removing Tool ", tools[iterations].name, "T", iterations M563 P{iterations} D-1 H-1 ;echo "disable heaters" while iterations < #heat.heaters if heat.bedHeaters[0] != iterations ;echo "Removing Temp Sensor and heater", sensors.analog[heat.heaters[iterations].sensor].name, "T", heat.heaters[iterations].sensor, "H", iterations M308 S{heat.heaters[iterations].sensor} P"nil" Y"nil" M950 H{iterations} C"nil" ;echo "remove fans" while iterations < #fans if fans[iterations] != null && fans[iterations ].name != "Power Supply" ;echo "Removing Fan", fans[iterations].name, "F", iterations M950 F{iterations} C"nil" M30 "0:/sys/lasttool.g"
Once reading I²C bus is implemented (it is maybe already done in current release, I didn't check yet), using a I²C EEPROM can be a way to identify a device; this is often used in consumer products (Gopro does or did that for their accessories).
@fma said in Invitation to share your conditional GCode scripts:
It also opens the possibility to store calibration data etc in the tool independent of the machine, ref IEEE1451-ish. Although Duet3d avoided using I2C for their fillament sensor (unlike Prusa) as the bus isn't intended for long runs. Maybe we'll see 1-wire or something in the future?
Well, the filement sensor needs continuous readings, which is not the case for calibration or so.
Nice! This will allow me to implement tool switching without the hassle of managing multiple config files!
This post is deleted! -
@OwenD said in Invitation to share your conditional GCode scripts:
Perhaps a forum section dedicated to this might be in order?
This now exists here: https://forum.duet3d.com/category/34/gcode-meta-commands
undefined T3P3Tony referenced this topic
