Invitation to share your conditional GCode scripts
@OwenD Please can I make a suggestion, at the beginning, issue a
M290 R0 S0
to reset baby stepping before you try to start performing jogging Z and trigger heights.
Just this minute made that mistake!
Paul
@PaulHew said in Invitation to share your conditional GCode scripts:
M290 R0 S0
Paul
Good idea!
So let it be written... -
Code to check if all axes are homed and optionally home them, or cancel macro.
It iterates across ALL axes making it more portable code (for those with >3 axis)
This saves manually listing them in an if || (or) statement such asif !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
I imagine this would be useful for tool changing printers where you might be doing something that may or may not require homing.
For the rest of us, I'd just run G28 if any are not homed.;first check if any axes are not homed and optionally home them while iterations < #move.axes if !move.axes[iterations].homed ; check if each axis is homed M291 P{"Axis " ^ move.axes[iterations].letter ^ " is not homed. Home now?"} R"Axis un-homed" S3 ; continue or abort? M98 P{"0:/sys/home" ^ (move.axes[iterations].letter) ^ ".g"} ; home axis if answer is OK - G28 doesn't accept object variable so run macro ; rest of code here
Here is what I use to choose machine type at startup depending on what tool is connected.
I include a resistor connected to the sensor pin inside the tool connector. This gives a fixed temperature reading and lets the machine choose its type depending on what is connected at startup.M308 S23 P"e2temp" Y"thermistor" T100000 B3950 A"ModeSelector" ;setup a thermistor input as config selection sensor ;wait for the sensor to start returning meaningful values (don't know if there is a better approach for this) while sensors.analog[23].lastReading==0||sensors.analog[23].lastReading==2000 echo ;print the value detected (useful when adding a new mode) ;M117 ModeSelector value:{sensors.analog[23].lastReading} ;depending on sensor reading choose a system folder if sensors.analog[23].lastReading==-273.1 M117 No Attachment Detected. elif sensors.analog[23].lastReading<155 M117 Going to be a CNC. M505 P"CNC" else M117 Going to be a 3D printer. M505 P"Printer" ;load config.g from the chosen system folder M98 P"config.g"
That’s pretty cool. I’m considering my using a serial line with some tiny85 chips that I have laying around to do the same thing. For now I write out a script that I try to call from config.g that just sets up the last executed tool script.
M28 "0:/sys/lasttool.g" M98 P"0:/macros/Config Scripts/Setup 3 to 1 Hotend" M29
I have a script that uses conditional code to clear out tools, fans, and heaters as well as de-energizing my relays (stepper bank switch).
;echo "check temperature" while iterations < #sensors.analog if sensors.analog[iterations] != null && sensors.analog[iterations].lastReading > 32 && sensors.analog[iterations].name != "PS" if sensors.analog[iterations].name != "Bed" abort "Must wait for tool head to cool down!!!" ;echo "set relays" M18 E ; Turn off Steppers for extruders G4 P100 M42 P0 S0 ; Ensure relay 0 is off M42 P1 S0 ; Ensure relay 1 is off M42 P2 S0 ; Ensure relay 2 is off G4 P100 ;echo "remove all tools" while iterations < #tools ;echo "Removing Tool ", tools[iterations].name, "T", iterations M563 P{iterations} D-1 H-1 ;echo "disable heaters" while iterations < #heat.heaters if heat.bedHeaters[0] != iterations ;echo "Removing Temp Sensor and heater", sensors.analog[heat.heaters[iterations].sensor].name, "T", heat.heaters[iterations].sensor, "H", iterations M308 S{heat.heaters[iterations].sensor} P"nil" Y"nil" M950 H{iterations} C"nil" ;echo "remove fans" while iterations < #fans if fans[iterations] != null && fans[iterations ].name != "Power Supply" ;echo "Removing Fan", fans[iterations].name, "F", iterations M950 F{iterations} C"nil" M30 "0:/sys/lasttool.g"
Once reading I²C bus is implemented (it is maybe already done in current release, I didn't check yet), using a I²C EEPROM can be a way to identify a device; this is often used in consumer products (Gopro does or did that for their accessories).
@fma said in Invitation to share your conditional GCode scripts:
It also opens the possibility to store calibration data etc in the tool independent of the machine, ref IEEE1451-ish. Although Duet3d avoided using I2C for their fillament sensor (unlike Prusa) as the bus isn't intended for long runs. Maybe we'll see 1-wire or something in the future?
Well, the filement sensor needs continuous readings, which is not the case for calibration or so.
Nice! This will allow me to implement tool switching without the hassle of managing multiple config files!
This post is deleted! -
@OwenD said in Invitation to share your conditional GCode scripts:
Perhaps a forum section dedicated to this might be in order?
This now exists here: https://forum.duet3d.com/category/34/gcode-meta-commands
