Many issues after upgrading to 3.0 RC-12
Well, another problem of course. The fans are not working:
New fan code:
M950 F0 C"Part" Q500 ; create fan 0 on pin fan0 and set its frequency
M950 F1 C"Hotend" Q500 ; create fan 1 on pin fan1 and set its frequency
M106 P1 S1 H1:2 T100 ; set fan 1 value. Thermostatic control is turned onold 2.x fan code which worked
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S1 I0 F500 H1:2 T100 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on -
my fans for comparison
; Fans M950 F0 C"fan0" ;Part Cooling Fan M106 P0 H-1 ; M950 F1 C"fan1" Q500 ;Hotend Fan M106 P1 S1 H1 T40 ; M950 F2 C"fan2" ;_RRF3_ define fan2 M106 P2 H-1
That worked for part fan, hotend fan is still not working for some reason. I also have dual extrusion. The only change i made was adding H1:2
M106 P0 H-1
M106 P1 S1 H1:2 T40EDIT: ah nevermind, im dumb. I had the fan plugged into the fan2 the entire time
Ok, I am making progress on getting everything working, still a few issues.
Does anyone know how I can tell the duet to home X, hit the endstop, move over 15mm and tell that to be the X home position? reason being, my endstop for X is actually too far off the bed.
@TheBasedDoge said in Many issues after upgrading to 3.0 RC-12:
https://duet3d.dozuki.com/Wiki/Gcode#Section_G92_Set_Position. So home X, move it 15mm, then use G92 X0.
You can also use a negative value for your M208 X minima such that 0 is the edge of the bed and the negative value is when the endstop is triggered.
@deckingman said in Many issues after upgrading to 3.0 RC-12:
G92 X0
Ok, this did the trick perfectly, now the nozzle is lined up with the corner of the bed. Thank you!
Next issue..... When I run my G29 it skips the back half of the bed entirely. I suspect I have something set wrong with the offsets or mesh config but I must not be understanding the math correctly
G29 Warning: Skipping grid point (20.0, 215.0) because Z probe cannot reach it Warning: Skipping grid point (70.0, 215.0) because Z probe cannot reach it Warning: Skipping grid point (120.0, 215.0) because Z probe cannot reach it Warning: Skipping grid point (170.0, 215.0) because Z probe cannot reach it Warning: Skipping grid point (220.0, 215.0) because Z probe cannot reach it Warning: Skipping grid point (270.0, 215.0) because Z probe cannot reach it Warning: Skipping grid point (270.0, 265.0) because Z probe cannot reach it Warning: Skipping grid point (220.0, 265.0) because Z probe cannot reach it Warning: Skipping grid point (170.0, 265.0) because Z probe cannot reach it Warning: Skipping grid point (120.0, 265.0) because Z probe cannot reach it Warning: Skipping grid point (70.0, 265.0) because Z probe cannot reach it Warning: Skipping grid point (20.0, 265.0) because Z probe cannot reach it 24 points probed, min error -0.018, max error 1.523, mean 0.769, deviation 0.410 Height map saved to file 0:/sys/heightmap.csv
Here are my definitions for Z probe offsets and mesh
; Z-Probe M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 A5 S0.02 ; set Z probe type to bltouch and the dive height G31 P500 X20 Y5 Z2 ; set Z probe trigger value, offset and trigger height M557 X20:290 Y15:290 S50 ; define mesh grid
My bed is a 300x300. I set it to 290x290 to allow for room for it to not hit the bed clips
Make sure your probe offset is correct. -X to the left, +X to the right. -Y to the front, +Y to the back.
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
Ah ok, that was wrong. my probe is front right of the primary nozzle, so i changed it now to read y-5
Still having the same issue, back third of the bed will not probe
G29
Warning: Skipping grid point (20.0, 265.0) because Z probe cannot reach it -
Please post your whole config.g file as it is now.
Ok, here it is. thank you!
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 10 2020 13:55:08 GMT-0400 (Eastern Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Hypercube" ; set printer name M667 S1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P4 S1 ; physical drive 4 goes forwards M584 X0 Y1 Z2 E3:4 ; set drive mapping M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E86.00:86.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min) M201 X5000.00 Y5000.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X300 Y0 Z0 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 A5 S0.02 ; set Z probe type to bltouch and the dive height G31 P500 X20 Y-5 Z3.7 ; set Z probe trigger value, offset and trigger height M557 X20:290 Y0:290 S50 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2 M143 H2 S280 ; set temperature limit for heater 2 to 280C M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1:2 T100 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" ; Board cooling fan M106 P2 S80 H-1 ; Tools M563 P0 S"Right Nozzle" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"Left Nozzle" D1 H2 F0 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings M575 P1 B57600 S1 ;paneldue settings to enable connection M564 H0 ;allow movement before homing M501 ;load config overrides
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 10 2020 13:55:08 GMT-0400 (Eastern Daylight Time) ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X300 Y0 Z0 S0 ; set axis maxima
That looks like a mistake - Y300 right??
Yeah that seems to have been it. I was using the RR config tool and I don't think it filled in any of this stuff correctly. I set my maxima for XYZ now correctly and ran the probing again and it seems to have worked.
One more thing - on my RR 2 FW the BLTouch only probed each spot 1 time, now it does it like 4 times. Is this a setting somewhere?
Also wondering on the correct way to do start Gcode with mesh enabled. I have this:
G29 S1 ;Load heatmap G28 G1 Z15.0 F7000 ;Move the platform down 15mm G92 E0 G1 F200 E3 G92 E0 G1 X150 Y150 F7000 ; Move Probe to middle of bed G30 ; Do a single probe
Should I change anything?
Yes, see the documentation for M558.
Got it - I just noticed this error after starting a print
Warning: the height map was loaded when the current Z=0 datum was not determined probing. This may result in a height offset.
I am watching the Z motor and it seems to be adjusting as the head moves around though.
So I read this and I am still a little confused why it's happening - because I did this:
"Move the nozzle over the centre of the bed and do a single G30 probe (G30 without parameters)."
The center of bed G30 is in my start gcode for each print.The only difference that I did not do is run the G29 while the printer was hot. Is this the reason the error is coming up?
You've loaded the heightmap before you've done the G30. That's the problem.
