Many issues after upgrading to 3.0 RC-12
without you finger on x and Y?
My X and Y endstops
;Endstop Configuration M574 X1 S1 P"xstop" ; _RRF3 M574 Y1 S1 P"ystop" ; _RRF3
if the endstops are not engaged what does it say in
Machine specific - Endstops? in DWC -
Yeah, that is without my finger on any endstops.
But just to see what would happen, i did this.
Changed:
G1 H1 Y-5 ; home Y axis
G1 H1 X-305 F300 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-5 ; then move slowly to Y axis endstopTo:
G1 H1 Y-305 ; home Y axis
G1 H1 Y-305 ; then move slowly to Y axis endstopnow it's working! I changed it in homey also.
oh its working in machine specific - endstop also... it changes correctly based on the trigger
Well, another problem of course. The fans are not working:
New fan code:
M950 F0 C"Part" Q500 ; create fan 0 on pin fan0 and set its frequency
M950 F1 C"Hotend" Q500 ; create fan 1 on pin fan1 and set its frequency
M106 P1 S1 H1:2 T100 ; set fan 1 value. Thermostatic control is turned onold 2.x fan code which worked
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S1 I0 F500 H1:2 T100 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on -
my fans for comparison
; Fans M950 F0 C"fan0" ;Part Cooling Fan M106 P0 H-1 ; M950 F1 C"fan1" Q500 ;Hotend Fan M106 P1 S1 H1 T40 ; M950 F2 C"fan2" ;_RRF3_ define fan2 M106 P2 H-1
That worked for part fan, hotend fan is still not working for some reason. I also have dual extrusion. The only change i made was adding H1:2
M106 P0 H-1
M106 P1 S1 H1:2 T40EDIT: ah nevermind, im dumb. I had the fan plugged into the fan2 the entire time
Ok, I am making progress on getting everything working, still a few issues.
Does anyone know how I can tell the duet to home X, hit the endstop, move over 15mm and tell that to be the X home position? reason being, my endstop for X is actually too far off the bed.
@TheBasedDoge said in Many issues after upgrading to 3.0 RC-12:
https://duet3d.dozuki.com/Wiki/Gcode#Section_G92_Set_Position. So home X, move it 15mm, then use G92 X0.
You can also use a negative value for your M208 X minima such that 0 is the edge of the bed and the negative value is when the endstop is triggered.
@deckingman said in Many issues after upgrading to 3.0 RC-12:
G92 X0
Ok, this did the trick perfectly, now the nozzle is lined up with the corner of the bed. Thank you!
Next issue..... When I run my G29 it skips the back half of the bed entirely. I suspect I have something set wrong with the offsets or mesh config but I must not be understanding the math correctly
G29 Warning: Skipping grid point (20.0, 215.0) because Z probe cannot reach it Warning: Skipping grid point (70.0, 215.0) because Z probe cannot reach it Warning: Skipping grid point (120.0, 215.0) because Z probe cannot reach it Warning: Skipping grid point (170.0, 215.0) because Z probe cannot reach it Warning: Skipping grid point (220.0, 215.0) because Z probe cannot reach it Warning: Skipping grid point (270.0, 215.0) because Z probe cannot reach it Warning: Skipping grid point (270.0, 265.0) because Z probe cannot reach it Warning: Skipping grid point (220.0, 265.0) because Z probe cannot reach it Warning: Skipping grid point (170.0, 265.0) because Z probe cannot reach it Warning: Skipping grid point (120.0, 265.0) because Z probe cannot reach it Warning: Skipping grid point (70.0, 265.0) because Z probe cannot reach it Warning: Skipping grid point (20.0, 265.0) because Z probe cannot reach it 24 points probed, min error -0.018, max error 1.523, mean 0.769, deviation 0.410 Height map saved to file 0:/sys/heightmap.csv
Here are my definitions for Z probe offsets and mesh
; Z-Probe M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 A5 S0.02 ; set Z probe type to bltouch and the dive height G31 P500 X20 Y5 Z2 ; set Z probe trigger value, offset and trigger height M557 X20:290 Y15:290 S50 ; define mesh grid
My bed is a 300x300. I set it to 290x290 to allow for room for it to not hit the bed clips
Make sure your probe offset is correct. -X to the left, +X to the right. -Y to the front, +Y to the back.
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
Ah ok, that was wrong. my probe is front right of the primary nozzle, so i changed it now to read y-5
Still having the same issue, back third of the bed will not probe
G29
Warning: Skipping grid point (20.0, 265.0) because Z probe cannot reach it -
Please post your whole config.g file as it is now.
Ok, here it is. thank you!
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 10 2020 13:55:08 GMT-0400 (Eastern Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Hypercube" ; set printer name M667 S1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P4 S1 ; physical drive 4 goes forwards M584 X0 Y1 Z2 E3:4 ; set drive mapping M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E86.00:86.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min) M201 X5000.00 Y5000.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X300 Y0 Z0 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 A5 S0.02 ; set Z probe type to bltouch and the dive height G31 P500 X20 Y-5 Z3.7 ; set Z probe trigger value, offset and trigger height M557 X20:290 Y0:290 S50 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2 M143 H2 S280 ; set temperature limit for heater 2 to 280C M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1:2 T100 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" ; Board cooling fan M106 P2 S80 H-1 ; Tools M563 P0 S"Right Nozzle" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"Left Nozzle" D1 H2 F0 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings M575 P1 B57600 S1 ;paneldue settings to enable connection M564 H0 ;allow movement before homing M501 ;load config overrides
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 10 2020 13:55:08 GMT-0400 (Eastern Daylight Time) ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X300 Y0 Z0 S0 ; set axis maxima
That looks like a mistake - Y300 right??
Yeah that seems to have been it. I was using the RR config tool and I don't think it filled in any of this stuff correctly. I set my maxima for XYZ now correctly and ran the probing again and it seems to have worked.
One more thing - on my RR 2 FW the BLTouch only probed each spot 1 time, now it does it like 4 times. Is this a setting somewhere?
Also wondering on the correct way to do start Gcode with mesh enabled. I have this:
G29 S1 ;Load heatmap G28 G1 Z15.0 F7000 ;Move the platform down 15mm G92 E0 G1 F200 E3 G92 E0 G1 X150 Y150 F7000 ; Move Probe to middle of bed G30 ; Do a single probe
Should I change anything?
Yes, see the documentation for M558.
Got it - I just noticed this error after starting a print
Warning: the height map was loaded when the current Z=0 datum was not determined probing. This may result in a height offset.
I am watching the Z motor and it seems to be adjusting as the head moves around though.
