For anyone still using endstop switches...
no fork types but lot of others
https://www.aliexpress.com/item/32973708437.html -
My previous printer had a microswitch for Z homing, similar to the picture below. To improve it's repeatability I remove the metal lever and had the carriage hitting it directly on the plastic actuator. My assumption was that the leverage ratio increases the repeatability error. I never done measurements to confirm it though.
i think weather or not the lever improves the repeatability comes down to the rigidity of the whole lever and pivot point.
@bearer, let's say that the lever is perfect and the core switch has repeatability error X, doesn't that error multiplied by leverage ratio of the lever?
@zapta hm, maybe I read the chart up there wrong, but seemed omrom with lever was less accurate and crouzet was more accurate - as such I assumed it had more to do with the quality of the lever than the lever itself. (could be wrong ofc)
lever must be stiff, normally on these switches lever is springy intentionally as accuracy is not really important
you want to probe with SHORT end of the lever, normally these switches probe with long end of the lever, again, accuracy is not important for normal use and long lever reduce force required to press the spring
so what you need to do is reverse it, use stiff lever and use a lever that's short on the probe side and long on the trigger side, this way you increase force required to press the lever (not a problem on our gear) and increase precision
Before I made the differential screw/optical endstop for the Z axis, I used a lever and cam to bump a microswitch. The lever position effectively reduced movement of the adjuster screw by about 1:8 and gave me approximately 100 um/turn of the screw similar to the differential screw. The difference is that the cam was not linear or very predictable, where the differential screw is.
You can see the adjuster on the far right side of this picture:
One reason I wanted to switch to an optical endstop was that the printed plastic lever/cam eventually got damaged by bumping the switch too hard.
It would probably still be OK if it were made of metal, or it might have broken the switch mount. Putting limit switches in direct opposition to the motion is generally a bad idea.
For resume after power outage I wonder is a completely different approach would work.
- When detecting power outage printer move itself to closest full step.
- Printer writes its position to a non volatile memory.
- On resume from power outage, printer energizes steppers at a full step and read the last stepper location from non volatile memory.
- (optional) Printer sanity check the resumed location by homing using a non accurate switch/sensor.
- Printer is now accurately resumed without using an accurate sensor.
Only if the printer doesn't move when the motors are de-energized. Some don't. Many do.
I have both a optical Z axis end stop sensor and a BLTouch.
I use the end stop sensor to do a high speed homing to within 5mm (appx) of the bed.
Later I set Z=0 using the BLTouch.
i use these proximity sensors https://www.ia.omron.com/product/item/1017/ on my micro mill and one of my printers. Havent checked the printer but the mill repeats within .003-.006mm. Far more accurate than a printer needs but better is good. Aside from being very repeatable I like the small, 3mm diameter sensor and the remote amp with LED indicator. They do have other models with a larger, threaded sensor. Cheap too. Never paid more than $15 for one and recently bought 5 for $40 with free shipping. All new.
@3DPMicro said in For anyone still using endstop switches...:
Cheap too. Never paid more than $15 for one...Where are you seeing those prices?
I did a few quick checks with my normal suppliers and am seeing prices in the $130-$160 range.
@fcwilt ebay. You may have to wait for the right deal but it will come.
Edit #2- Don't know about posting (US) eBay links here so I won't but I just checked and the seller I bought from is still selling them for $8.01 each. New. -
Go for it. It's in context.
I'm thinking about building one myself like a 3d probe, but the long rod 90 degree angled like:
This should be very precise. -
@JoergS5 What is that?
@mrehorstdmd Something like https://www.youtube.com/watch?v=prb60JoxQSQ but as endstop. The three red pairs (often steel balls) are electrically connected with the shaft, a small movement lifts the shaft, disconnecting. I find it interesting because it doesn't bend anything at contact, should be repeatable.
@fcwilt I have not. Might look on Omrons site, see if they offer one and then check eBay.
