Rat rig v-core pro COREXYU
hi guys,
I give up 12v output, nothing comes out,only from 24v on the dux5 outputs, despite the jumper on 12v,
someone know a simple way to go down to 12 v while keeping control of the layer fans ??
I have SODIALs (LM2596 DC-DC fan 12v),
but I can't manage the flow with its always 100%
thank yousalut les gars,
J'abandonne la sortie 12v, rien ne sort,uniquement à partir de 24v sur les sorties dux5, malgré le cavalier sur 12v,
quelqu'un connaît un moyen simple de descendre à 12 v tout en gardant le contrôle des ventilateurs de couche ??
J'ai des SODIAL (LM2596 ventilateur DC-DC 12v),
mais je ne peux pas gérer le flux avec son toujours à 100%
Merci -
Yes you can use a buck converter (LM2596).
The negative lead must go back to the negative pin on the fan port directly. The Duet switches PWM on the negative side.
See here: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s214
@neetspeed do you have a jumper on INT 12V EN on the left of the board? See https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/3wbm6g2qRUBfSHgw.huge
You can check for 12V on the pins next to it.https://duet3d.dozuki.com/Wiki/Duex_wiring_diagrams#Section_Warnings_and_Cautions
In order to use the 12V internal supply for LEDs/FANs the 12V EN jumper must be fitted. Do not fit this jumper if you are not using the 12V internal supply
duet 2 starts more,
seeing blue wine light up and nothing else bizzare,
it worked 10 min ago i have nothing to touch up lolle duo 2 commence plus,
voir du vin bleu s'illuminer et rien d'autre de bizzare,
ça a fonctionné il y a 10 min je n'ai rien à retoucher lol -
@neetspeed sounds like the 5V regulator has failed. Post a high resolution good quality picture of your board. If you connect USB power, does it work? If not, is the processor getting hot? Test with your finger, but be careful.
@droftarts also follow this guide https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
Its not good, or I dream?
on the usb pc, its an error message
on usb charger everything turns on but my lamp which has a usb socket goes out so much the duet 2 draws current I think
you have an opinion or to change?
the photo is coming
Ce n'est pas bon, ou je rêve?
sur le pc usb, c'est un message d'erreur
sur le chargeur usb tout s'allume mais ma lampe qui a une prise usb s'éteint tellement le duo 2 tire du courant je pense
vous avez une opinion ou changer? -
@neetspeed There may be a burn mark on the top of U3, which is near the fuses. Can you take a close up picture of that area? Also, unplug the stepper motor from Z driver, it’s plugged in incorrectly, on only 3 pins!
no the stepper motor z is not connected,
it is to replace a lost jumper c connect on two pins in closed circuit
the photo is coming
thank younon le moteur pas à pas z n'est pas connecté,
c'est pour remplacer un cavalier perdu c se connecter sur deux broches en circuit fermé
la photo arrive
Merci -
I think you're right,
I see a hole, it looks like
but I have nothing to touch on the duet I connected the fan to the duex5, I saw I had no 12v I connected LM2596
Je pense que tu as raison,
Je vois un trou, on dirait
mais je n'ai rien à toucher sur le duo j'ai branché le ventilateur sur le duex5, j'ai vu que je n'avais pas de 12v j'ai branché LM2596 -
@neetspeed said in Rat rig v-core pro COREXYU:
LM2596
How did you connect this? I’d think it is likely you put 12V into the 5V rail. See https://duet3d.dozuki.com/Wiki/How_to_destroy_your_Duet_2
Did you see my post about the 12V enable jumper?
Je les ai soudés sur des câbles et j'ai connecté les ventilateurs correctement tournés,
J'ai regardé la page du 12v, DUEX5
et j'avais une question mais je la remettais à plus tard,
mais c'est vrai que j'ai été et rallumé la machine plusieurs fois j'ai vu un fil coupé dans mon faisceau de câbles pour l'axe UJe les ai soudés sur des câbles et j'ai connecté les ventilateurs correctement tournés,
mais c'est vrai que j'ai été et rallumé la machine plusieurs fois j'ai vu un fil coupé dans mon faisceau de câbles pour l'axe U -
Pensez-vous qu'il est mort dans le duo 2nd ou puis-je faire quelque chose?
I changed the jumper to red,
I place them o milieur on the 12v and nothing in the fan
I hesitated with the purple I said to myself I would ask the question
J'ai changé le pull en rouge,
Je les place o milieur sur le 12v et rien dans le ventilateur
J'hésitais avec le violet je me suis dit que je poserais la question -
if you confirm to me that he died,
I will have to order a new one,
my brain has bugged on the model clone
but the best part of me brings me back to reason,
and tells me that nothing like rewarding the creators, the quality and the advice of the community including the corexy formula with idex mark forged that you and dc42 have me to carry is priceless and I hope that readers will make the right choice, if there was to do by reading ussi vous me confirmez qu'il est mort,
Je vais devoir en commander un nouveau,
mon cerveau a buggé sur le clone du modèle
mais la meilleure partie de moi me ramène à la raison,
et me dit que rien de tel que de récompenser les créateurs, la qualité et les conseils de la communauté, y compris la formule corexy avec la idex mark forged que vous et dc42 m'avez à porter, n'a pas de prix et j'espère que les lecteurs feront le bon choix, s'il y avait à faire en nous lisant -
@neetspeed can you answer these questions, please.
Where did you buy your Duet? And when? Because it looks genuine to me, not a clone.
Do you actually have a Duex?
Did you connect the LM2496? If yes, how?If the USB port reports too much current draw then something is taking too much 5V or 3.3V power. it cold be the blown U3. or it could be the processor, SD card, WiFi module etc. It may be repairable, by replacing U3, but other components may be damaged.
A blown U3 is normally a warranty replacement, because it shouldn't happen even if the board is mis-wired. Warranty is 6 months.
the card is authentic duet
but I buy them in a new batch, and pack but the warranty is over.
I will order a new one I think these are the best things to do
c order
@neetspeed I don’t think you should use the LM2596 like that, it won’t work and may damage the Duet/Duex. If you are trying to feed 12V to all fan pins on Duex, remove the DC converter, and put jumper on 12V enable, highlighted in purple in the diagram you posted earlier. This does make all fans on Duex 12V. It’s missing in your image above.
If you must use external 12V, see https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V
Thanks for your order!
