Large Delta printer not homing on an original duet Maestro
Also, the message when triggered should say "at max stop". Yours says min.
Please re-verify that M574 X2 Y2 Z2 S1
has 2 (two) on each axis, and S1, and that the printer has been restarted.
Also, could you copy and paste the contents of your config.g and homing files as text into a post? The screenshots are pretty hard to see and we can't copy and paste from it.
i mesured continuity between the left pin and middle pin, when i press the endstop, thats when it conducts. so it is an active high endstop ( left pin and middle pin i am using, left is ground and middle is 3,3v in the board).
( left orange, middle white wires.)
I have checked the config file again and i have restarted the printer after changing S0 to S1 i will include a screenshot.
@NEVER-LUCKY said in Large Delta printer not homing on an original duet Maestro:
If those are the two pins that are wired to the Duet, that is a NO (Normally Open) switch.
I would highly recommend changing the wiring. NC (Normally Closed) switches have lots of advantages. Wire the switch terminals the conduct (per your meter), when the switch is NOT pressed, and the open (per your meter) when the switch is pressed.
There is no third wire.
Which board are you using? Duet 2 or Duet 3?
im using a duet 2.
what do you mean by "per your meter" ?
im not so familiar with all the terms. -
When you measured continuity.
You want the pins that HAVE continuity when the switch is NOT pressed, and therefore that BREAK continuity when the switch is pressed. This is "normally closed", meaning "normally with continuity"
oh, right im doing that right now, do i need to change something in the files or just adjust the wires?
Adjust the wires to be NC, then the S1 should work.
Once you have it adjusted, check this again.
alright we are getting someware
the exruder also has an endstop, should it also be No when i havent loaded any filament?
right now it is saying Yes but i havent loaded filament. the extruder doesnt have the same endstop as the axes so i will have to buy one for it aswell. -
The extruder doesn't really need an endstop. You can use it as a trigger for something else like a filament monitor or runout switch, but it's not required.
noted. so now when i press the X endstop it doesnt turn Yes while the Y and Z turn Yes. does it mean the X endstop is busted?
possibly. What does it show on your multimeter? Double check your crimps and wire continuity.
Yay, that is progress!
And, yes, pursue what @Phaedrux said...
i did the crimps again on X and it seems to work i guess ?
when i press X, index 0 is Yes
when Y, index 2 is Yes
when Z, index 1 is yesdoes that mean that i have the X Y and Z wrong ?
does that mean that i have the X Y and Z wrong ?Looks like you have the Y and Z endstop wires swapped over.
but does it really matter though? because when the endstop triggers for a particular axis, it only registers it for that one or not?
It's vital that the X (index 0) endstop is on the same tower as the carriage that moves up 10mm when you send G91 G1 H2 X10. Likewise the Y (index 1) endstop must be on the same tower as the carriage that moves up when you send G1 H2 Y10; and similarly for index 3 and Z. Otherwise, when an endstop is triggered it will stop the wrong motor.
the red diag LED is lit, green blue and other red is also lit, but the board is not connecting to the web interface
i dont understand..... why is the board not responding on YAT ??? are these boards this fragile?
