Obsolete use of S parameter on G1 command...
@jens55 you are right dude I had missing to remplace one "S" argument by "H" in homez.g at here
G91 ; relative positioning G1 Z5 F6000 S2 <--(problem is here, remplace S2 by H2) ; lift Z relative to current position G90 ; absolute positioning G1 X152 Y166.4 F6000 ; go to first probe point G30
Thank you for focusing me on it.
Now I'll try to learn to make probing Z with IR sensor to work. -
@dc42 In short I had not used the printer in a while so I just started again with the latest firmware update.
I just change all the S commands to H's and I am still getting the errors:
SetPositions called when DDA ring not empty
G28
Error: G29: Must home printer before bed probing -
G28
Error: G29: Must home printer before bed probingDo I only change the parameters in the homexxx files? or everywhere?
I've edited all of these files:
homeall.g
homedelta.g
homex.g
homey.g
homez.gThank you !
@Stephenbright said in Obsolete use of S parameter on G1 command...:
This is an error that I haven't managed to reproduce yet. It's on my list to look at next week.
@dc42 Question: Do I change ALL of the "S" commands to "H" commands in ALL of the config files or just the "home" As of now I've just edited the "home" files and nothing has changed or worked and I get the same errors... OR do I literally just change anything with a G1 command? Thank you !
You need to change all the files you listed above! That is to say
homeall.g
homedelta.g
homex.g
homey.g
homez.gbut if you have any other files that use G1 that run at the very start then you need to change those too. The S parameter is used to (I think) allow movement when not all the axis have been homed so anything you added that moves any of the axis under non homed conditions need changing.
In a cartesian system it is homeall, homex,homey,homez but I do not know if a delta printer has other files. -
Thank you and yes that is what I had thought so I have in fact changed all of the G1 commands only. ( I should have clarified that ) not every S to and H but just the G1 parameters... I'm going to double check to make sure I haven't missed any. Is there any other place I should look as I thought I got them all?
That being said I'm still getting nothing to home at all. Basically it's doing nothing but giving me that error...
I found this S1 in: print_stopgcode.g file. Should that be changed?
G1 Z5 S1 F360 ; lower Z by 5mm, or until Z-limit is reached
and G0 if used. i don't think G2 and G3 support H parameter, but might wanna check for completeness
I double checked my files and found an S1 I had overlooked. I suspect you have overlooked one as well.
You are right in only changing 'S' parameters in G1 (or G0) moves.
That error is not what is stopping the homeing - it only throws the error but doesn't stop anything from running so there is something else amiss.
Here is my homex.g file but note it's for a cartesian printerG91 ; relative positioning
G1 Z5 F6000 H2 ; lift Z relative to current position
G1 H1 X-505 F10000 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G1 H1 X-505 F360 ; move slowly to X axis endstop once more (second pass)
G1 Z-5 F6000 H2 ; lower Z again
G90 ; absolute positioningCompare that to your homex and see if there are any definite differences. If this doesn't get you past 'not moving anything' problem then please post your homeing files and your config.g file so we can see what is going on.
@jens55 said in Obsolete use of S parameter on G1 command...:
To be clear, the warning about using S instead of H is currently just that: a warning. It doesn't change the behaviour.
Part one: The obsolete S and H parameters warning is now gone so I think I have that fixed...
Right now I had manually put the core XY and the bed in to the home positioning and then restarted the machine. I am NOW getting movement, however its grinding all over the place as I'm sure nothing is aligned and needs to be set up, however how do I do that when its freaking out like that??
Below is the config file. Do you need ALL of the homing files to look at? And is it okay to post it like the config file below?
Thank you BOTH for all of your help !
; CONFIGURATION FILE for Duet Maestro
; K'Tana Nozzle
; Last modified October 1, 2018; Executed by the firmware on start-up
; Headers within parenthesis are headings in Duet3D documentation=https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer
; Visit https://reprap.org/wiki/G-code for an explanation of G-code commands; --- SECTION: GENERAL PREFERENCES ( ) ---
M564 S1 H1 ; Enables Homing Requirement For Motor Activation and set axes limits
; --- SECTION: Z-PROBE & MESH COMPENSATION ---
M98 Pmachine_zprobe.g ; configure the z probe
M98 Pmachine_bedmesh.g ; configure the bed mesh
G29 S1 ; Load heightmap after power cycle
; --- SECTION: DRIVES (MOVEMENT SECTION) & ENDSTOPS ---
M667 S1 ; Enable coreXY mode
M569 P0 S0 D3 V0 ; Drive 0 goes forwards, CoreXY_1, stealth chop, disable spread cycle
M569 P1 S1 D3 V0 ; Drive 1 goes forwards, CoreXY_2, stealth chop, disable spread cycle
M569 P2 S1 D3 V0 ; Drive 2 goes forwards, Z Motor, stealth chop, disable spread cycle
M569 P3 S0 D3 V800 ; Drive 3 goes forwards, Left Extruder, stealth chop, spread cycle only on retractions (basically)
M569 P4 S1 D3 V800 ; Drive 4 goes forwards, Right Extruder, stealth chop, spread cycle only on retractions (basically)
M98 Pmachine_endstoptypes.g ; set endstop types
M98 Pmachine_steppercurrent.g ; set stepper currents
M98 Pmachine_stepperspeed.g ; set stepper speeds
M98 Pmachine_axisdimension.g ; configure the axes dimensions
M98 Pmachine_axissteps.g ; configure the axes steps per mm
M98 Pmachine_extruderstep.g ; configure the extruder steps
G21 ; Work in millimetres
G90 ; Set to absolute coordinates...
M84 S1 ; Set idle timeout; --- SECTION: HEATERS, BED & THERMISTOR ---
; H0 is bed
; H1 is left heater
; H2 is right heaterM570 H0 P25 T30 ; Allow heater to be off by as much as 30C for 25 seconds
M570 H1 P15 T30 ; Allow heater to be off by as much as 30C for 15 seconds
M570 H2 P15 T30 ; Allow heater to be off by as much as 30C for 15 seconds
M305 P0 T100000 B4138 C0 R2200 ; Set thermistor + ADC parameters for heater 0, For heated Bed thermistor
M305 P1 X501 R2200 ; Define left side extruder PT1000
M305 P2 X502 R2200 ; Define right side extruder PT1000
M307 H0 A78.9 C265.2 D9.5 S1.00 V24.0 B0 ; Forcing heated bed PID control after power-cycle. Basic bed heating auto-tune
M307 H1 A309 C96 D5.2 S0.75 V24.1 B0 ; Set PID values use M303 auto-tune calibration settings
M307 H2 A309 C96 D5.2 S0.75 V24.1 B0 ; Set PID values use M303 auto-tune calibration settings
M302 P1 ; Allow Cold extrudes
M98 Pmachine_maxtemp.g ; set bed and extruder max temperatures; --- SECTION: FANS ( ) ---
M106 P0 S0 I0 F4 H-1 L0.3 ; Filter fan. Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off, Minimum fan value 0.3, Speed 100%
M106 P1 S0 I0 F4 H-1 L0.3 ; Cold-Section fan. Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off, Minimum fan value 0.3, Speed 100%
M106 P2 S0 I0 F4 H-1 L0.3 ; Nozzle fan. Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off, Minimum fan value 0.3, Speed 100%; --- SECTION: TOOLS ( ) ---
; Comment: Remember! H0 is the heated bed!
; Comment: D0 is the first driver after movement (X, Y and Z) drives, which is left extruder
; D1 is right extruderM98 Pmachine_ktana_tools.g ; Define ktana tools
T0 ; Automatic tool select
; --- SECTION: NETWORKS (PROLOGUE & COMMUNCATIONS SECTION) ---
M98 Pmachine_access.g ; set machine name and IP
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; --- SECTION: MISCELLANEOUS ---
M572 D0:1 S0.07 ; Extruder Pressure Advance
;M98 Pqc.g ; Do NOT uncomment unless you really know what you're doing -
; homex.g
; called to home the X axis
; October 4, 2018; same as homey.g because of coreXY
; Front left corner is (0,0); ============= PRE-HOMING =====================
; Ignore Machine boundaries
M564 H0 S0; Turn off bed leveling during homing
G29 S2 ; Does the same as M561!; Switch to Origin Tool
T0; Relative positioning
G91; Provide Z height clearance
G1 Z10 F750 H1; ================== HOME Y ============================
; Rapid Y until limit switch triggers
G0 Y450 F1500 H1; Back off to release limit switch
G0 Y-6 F1500; Slow advance to trigger limit switch
G0 Y10 F120 H1; Set this location as Y = 384mm
G92 Y384; Move the gantry slightly away from back of printer, to allow travel past the bolt mounting the gantry bracket
G0 Y-5 F1200; ============= HOME X ====================
; Rapid X until limit switch triggers
G0 X450 F1500 H1; Back off to release limit switch
G0 X-6 F1500; Slow advance to trigger limit switch
G0 X10 F120 H1; Set this location as X = 380mm
G92 X380; Move away from the limit switch, to prevent damage to it upon next move
G0 X-5 F1500; ============ Post-Homing ==============
; Revert to absolute coordinates
G90; Re-enable mesh leveling
G29 S1M98 Pmachine_axisdimension.g ; Set Axes Limits
; Stop movement across limits, enable boundaries, homing requirement
M564 H1 S1 -
; homez.g
; called to home the Z axis
;; ============= PRE-HOMING =====================
G29 S2 ; Do it twice because once just isn't enough; Switch to Origin Tool
G1 Z10 F750 H1; ============ HOME Z ==============
; Rapid Z until limit switch triggers
G0 Z450 F1500 H1; Back off to release limit switch
G0 Z-15 F1500; Slow advance to trigger limit switch
G0 Z20 F120 H1M98 Pmachine_zendstop.g ; Set Z Endstop height
M98 Pmachine_zprobe.g ; Set Z Probe distance; ============ Post-Homing ==============
M564 H1 S1 -
; homey.g
; called to home the Y axis
;; Same as homex.g because of coreXY
; Front left is (0,0)M98 Phomex.g
; homeall.g
; called to home all axes
;; Front left corner is (0,0)
; ============ HOME X & HOME Y ==============
M98 Phomex.g ; Run the homex.g file, also homes the Y axis
M98 Phomez.g ; Run the homez.g file
@dc42 Stephenbright 20 Jan 2020, 20:53
G1 Z10 F750 H1Is the intention here to seek an endstop, or to move the axis before it's been homed? H1 would seek the endstop, H2 would allow movement before homing. Failing to reach the endstop could cause you issues.
@Phaedrux I think I need to set the end stops first in the homed position. Right now it seems confused like its trying to home and move the axis in a different direction at the same time...
I think I initially did the same thing, but yes, if you remove the H1 it should still not crash as long Z is homed before running homex as the soft limit would stop the axis at the limits defined by M208 (280?)
And if z is not homed before running homex it should fail saying insufficient axis homed when you try to move z.
