syncronizing 2 z-steppers
@spllg said in syncronizing 2 z-steppers:
remove this line:
M574 Z1 S1 P"io5.in" ; configure active-low endstop for low end on Z via pin io5.in
and uncommend the M558 command
->do i need m557 for just synching the z-steppers?
no its for mesh
@SIam removing m574 seems to disable z-homing - Error: Failed to enable endstops
2569 P0.3 S1 D2 ; physical drive 0.3 goes forwards ; Z - left
that line is not correct.
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1B4138 is the default and wrong for your thermistors.
@Veti said in syncronizing 2 z-steppers:
B4138
corrected - thanks for the hint, but apparently it does not solve my problem (but maybe others .
From my understanding. you are trying to say the the Z endstop and probe is io5.in and
Do you have a z endstop and probe?if you have both then i think you need to use diffenrt pins and codes.
I dont have the Duet 3
so cant confirem but i dont think you can use the same pin for both Z endstop and Probe. -
@SLKittie said in syncronizing 2 z-steppers:
Do you have a z endstop and probe?i only have a probe and use it successfully for z-homing and want to use it as z-probe as well.
so cant confirem but i dont think you can use the same pin for both Z endstop and Probe.that's what i'm afraid of. so, should i try to connect io5.in to io6.in and use io5.in as zstop and io6.in as z-probe? any opinions?
You may need to have a look at these websites as you dont have the configerastion for the probe set up. as there is no G31 command after your M558 to say where the prob is and how to activae it.
https://duet3d.dozuki.com/Wiki/Setting_up_automatic_probing_of_the_print_bed
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
Just out of curiosity how do you code your Config.g?
thanks for the hints - going to read tomorrow (i find it hard to get started because i feel information is kind of scattered)
initial version was generated by a reprap website (i have forgotten the url)..
do i really need distinct z-endstop and z-probe? i cannot believe this.
If you use the Z probe to home Z then you don't need a Z endstop. https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z
I use a single microswitch, defined as a probe, to both home and auto-bed-level (three motors) and mesh probe a bed on a CoreXY.
So, define a probe for Z, and don't define an endstop for Z, and it "just works".
I'm doing same thing, I did have to define Z-Probe in my config.g though. I'm having issue with 1 side dropping but I don't believe it is related to the issue you're having. Here is my config G and you can see Z-Probe settings
; generated by RepRapFirmware Configuration Tool v2.1.4 on Tue Dec 24 2019 07:12:07 GMT-0500 (Eastern Standard Time); General preferences
M550 P"Alex's Hypercube" ; set printer nameM667 S1 ; select CoreXY mode
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M584 X0 Y1 Z2:4 E3 ; set drive mapping
M671 X-30:330 Y156:156 S1.5 ; leadscrews at left and right
M92 X161 Y160 Z809 E819 ; set steps per mm
M203 X18000.00 Y18000.00 Z300.00 E350 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E350 ; set accelerations (mm/s^2)
M906 X1400 Y1400 Z1400 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X0 Y0 Z-5 S1 ; set axis minima
M208 X280 Y280 Z370 S0 ; set axis maxima; Endstops
M591 D0 P5 C3 R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled; Z-Probe
M558 P1 XO YO H3 F200 T9000 B1 R0.1 A5 ; set Z probe type to modulated and the dive height + speeds
G31 P500 X-27 Y0 Z1.650 ; set Z probe trigger value, offset and trigger height
M557 X20:240 Y20:260 S220 ; define mesh grid; Heaters
M305 P0 T100000 B4725 C7.06e-8 ; set thermistor + ADC parameters for heater 0
M307 H1 A390.9, C258.2, D5.4, S1 ; hot end thermister tuning
M305 P1 T100000 B4725 R4700 ; set thermistor + ADC parameters for heater 1
M106 P2 S0.5 I0 F500 H1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossHere is my bed.g
; bed.g
; generated by RepRapFirmware Configuration Tool v2.1.4 on Tue Dec 24 2019 07:12:06 GMT-0500 (Eastern Standard Time)
G28 ;home
G30 P0 X0 Y156 Z-99999 ; probe left leadscrew
G30 P1 X260 Y156 Z-99999 S2 ; probe right leadscrew and calibrate 2 motors
G29 ; run mesh bed leveling -
@Danal this sounds interesting, do you have any pictures so I can get an idea of how to maybe adapt this to mine. I currently run a DC42 IR sensor and I think it may not be the most reliable and a BL touch has more wires and I already have a 22 pin connector full on my X carriage and don't have room to run the extra 2 for the BL Touch neatly so this may give me a better option.
I will get a pic... but the microswitch is just on the bottom of the carriage that grabs tools (this is a toolchanging printer).
Definition statements for all endtstops and probes:
; Endstops and probes M574 X1 S1 P"io1.in" ; Set homing switch configuration X1 = low-end, S1 = active-high (NC) M574 Y1 S1 P"io2.in" ; Set homing switch configuration Y1 = low-end, S1 = active-high (NC) M574 U1 S1 P"io3.in" ; Set homing switch configuration U1 = low-end, S1 = active-high (NC) ;M574 Z1 S1 P"!io4.in" ; Set homing switch configuration Z1 = low-end, S1 = active-high (NC). This is used for tool probing, not actual Z height. M558 K0 P5 C"io4.in" H5 A5 T6000 S0.02 ; Z probe - Set the height of the bed when homing G28. Combined with content of bed.g as invoked by G32, levels bed. Also used for Mesh. ; P5 = Switch, NC ; C = Input Connector ; Hn = dive height ; A bigger dive height prevents a situation where the bed is out of alignment by more than the dive height ; on any corner, which can crash the hot-end into the bed while moving the head in XY. ; Probing speed and travel speed are similarly reduced in case the Z probe isn't connected properly (or ; disconnects later after moving to a point) giving the user more time to stop. ; An = Number of times to probe each point. ; Tnnn = Travel speed between probe points. ; Snnn = Tolerance when probing multiple times. Two readings inside this window and we move on.
@dc42 thank you very much for this valuable hint.
@Danal i do not have a z-endstop mounted near the nozzle - i don't hav a z-endstop at all.
dc42's hint solved my issue.
