Unsolved CR-10S5 Firmware
@Veti the JK42HS42-1704 motor linked on that page is 1.7A. Looks like there is some variation on what creality strapped to their machines?
Perhaps their board doesn't work well at higher currents?
Edit: There are 4 JK42HS40-* motors. A resistance check should confirm which it is. The 30ohm resistance is unlikely. They come in 1.7, 1.3, and 1.2A rated models.
Note for the original poster. Don't change current without confirming which motors are strapped to your machine. If in doubt, leave as is.
All of the endstops switch to NO upon being at zero, however the endstop is not stoping the axis from wanting to move after the endstop has been triggered. They Y motor moves now perfectly, seemed to be a loose wire on the connector attached to the motor.
Endstops are only active when doing a homing move with G1 S1
Cool beans, that is the next task. I need to fix the homing functions next, as they don't move the intended motor. I'm also still having a probelm with syncing the z axis. Going down is fine, however going up will produce a stair case affect (one motor will spin while the other doesnot then the motors switch and do the same thing)
All of the homing functions are fixed, I'm at a restaurant right now, but I will post the config and home files when I get back. Is there a way to make the z move fast on the way down, but slow on the way up?
Home ALL homeall (1).g
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v2.0.3 on Wed Sep 11 2019 20:24:24 GMT-0600 (Mountain Daylight Time) ; Y G91 ; relative positioning G1 S1 Y-505 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 Y5 F6000 ; go back a few mm G1 S1 Y-505 F360 ; move slowly to Y axis endstop once more (second pass) G90 ; absolute positioning ; X G91 ; relative positioning G1 S1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 X5 F6000 ; go back a few mm G1 S1 X-505 F360 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning ; Z G91 ; relative positioning M92 Z400.00 ; Move Z Fast G1 S1 Z-505 F3000 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this) G1 Z1 F6000 ; go back a few mm M92 Z80 ; Move Slow G1 S1 Z-505 F400 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning
Home X homex.g
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v2.0.3 on Wed Sep 11 2019 20:24:24 GMT-0600 (Mountain Daylight Time) G91 ; relative positioning G1 S1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 X5 F6000 ; go back a few mm G1 S1 X-505 F360 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning
Home Y homey.g
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v2.0.3 on Wed Sep 11 2019 20:24:24 GMT-0600 (Mountain Daylight Time) G91 ; relative positioning G1 S1 Y-505 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 Y5 F6000 ; go back a few mm G1 S1 Y-505 F360 ; move slowly to Y axis endstop once more (second pass) G90 ; absolute positioning
Home Z homez (1).g
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v2.0.3 on Wed Sep 11 2019 20:24:24 GMT-0600 (Mountain Daylight Time) G91 ; relative positioning M92 Z400.00 ; Move Z Fast G1 S1 Z-505 F3000 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this) G1 Z1 F6000 ; go back a few mm M92 Z80 ; Move Slow G1 S1 Z-505 F400 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning
I just got my BLTouch in today, but I will have to print out the mount once this can print.
What I have to do next:
Either figure out:
Why my hot end thermister is not working.
-Possibly rewire
Why my hotend will not heat up.
-Possibly rewire
-Wait for the new one to arrive: Here
Figure out how to use a filament sensor
Replace Main Hotend fan for a Noctua fan: Here -
@Gost101 said in CR-10S5 Firmware:
M92 Z80 ; Move SlowNope, this isn't right. You're changing the steps per mm value for the axis, which isn't changing the speed it's changing how far it's moving per rotation. Not sure what the intention is there.
When you switch to a z probe you can follow the guidance here for setting up the probe and the Z homing macro:
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
Is there a way to make the axis move faster besides changing the steps/mm?
Change the feed rate of the move.
Which command is that?
That's the F parameter of the G1 moves
Here is the latest config files.
I need to print the BLTouch mount before I can begin using it.
Everything heats up, however I'm having trouble with the e3D Volcano extruding (I just bough a Bondtech Extruder to hopeful solve this as the stock extruder is skipping. I will try to see if the hotend is clogged, I don't think it is due to being a e3D nozzle X.
Everything works at the moment, so I will attempt a benchy.Config.g: config.g
;config.g ; Created by Gost101 on Saturday, September 28th, 2019 at 18:00 MST (6:00PM for Civs). ; This firmware discussion can be found on duet fourm: https://forum.duet3d.com/topic/11964/cr-10s5-firmware/37 ; Contact gost1017@gmail.com for more help. ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"A.C.E." ; set printer name M669 K0 ; select Cartesian mode ; Network M551 P"12345" ; set password M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; X physical drive 0 goes forwards M569 P1 S1 ; Y physical drive 1 goes forwards M569 P2 S0 ; Z physical drive 2 goes backwards M569 P2 S0 ; Z physical drive 2 goes backwards M569 P3 S1 ; E physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y78.00 Z400.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z1400.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z1400.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z1400.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z8000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0:500 Y0:500 Z0:500 ; set axis maxima ; Endstops M574 X1 Y1 Z1 S1 ; set active high endstops ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
Home All: homeall.g
; homeall.g ; Created by Gost101 on Saturday, September 28th, 2019 at 18:00 (6:00PM for Civs). ; This firmware discussion can be found on duet fourm: https://forum.duet3d.com/topic/11964/cr-10s5-firmware/37 ; Contact gost1017@gmail.com for more help. ; Y-Axis G91 ; relative positioning G1 S1 Y-505 F3000 ; move quickly to Y axis endstop and stop there (first pass) G1 Y5 F1000 ; go back a few mm G1 S1 Y-505 F360 ; move slowly to Y axis endstop once more (second pass) G90 ; absolute positioning ; X-Axis G91 ; relative positioning G1 S1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 X5 F6000 ; go back a few mm G1 S1 X-505 F360 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning ; Z-Axis G91 ; relative positioning G1 S1 Z-505 F10000 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this) G1 Z3 F800 ; go back a few mm G1 S1 Z-505 F80 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning
Home X: homex.g
; homex.g ; Created by Gost101 on Saturday, September 28th, 2019 at 18:00 MST (6:00PM for Civs). ; This firmware discussion can be found on duet fourm: https://forum.duet3d.com/topic/11964/cr-10s5-firmware/37 ; Contact gost1017@gmail.com for more help. G91 ; relative positioning G1 S1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 X5 F6000 ; go back a few mm G1 S1 X-505 F360 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning
Home Y: homey.g
; homey.g ; Created by Gost101 on Saturday, September 28th, 2019 at 18:00 MST (6:00PM for Civs). ; This firmware discussion can be found on duet fourm: https://forum.duet3d.com/topic/11964/cr-10s5-firmware/37 ; Contact gost1017@gmail.com for more help. G91 ; relative positioning G1 S1 Y-505 F3000 ; move quickly to Y axis endstop and stop there (first pass) G1 Y5 F1000 ; go back a few mm G1 S1 Y-505 F360 ; move slowly to Y axis endstop once more (second pass) G90 ; absolute positioning
Home Z: homez.g
; homez.g ; Created by Gost101 on Saturday, September 28th, 2019 at 18:00 MST (6:00PM for Civs). ; This firmware discussion can be found on duet fourm: https://forum.duet3d.com/topic/11964/cr10s5-firmware/37 ; Contact gost1017@gmail.com for more help. G91 ; relative positioning G1 S1 Z-505 F10000 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this) G1 Z3 F800 ; go back a few mm G1 S1 Z-505 F80 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 S2 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
Your thermistor settings are wrong for both your bed and hotend.....The bed should be M305 P0 T100000 B3950 R4700 and the volcano if it has the E3D cartridge thermistor should be M305 P1 T100000 B4725 C7.060000e-8 R4700
Thanks, I changed that before this print: ![alt text]
I've got a lot of tweaking to do.
It's not... THAT bad... I guess.
The e3D volcano keeps getting clogged. In between the nozzle and the Capricorn tube there is a little gap that wont close and the filament expands into that and wont let me extrude. I purchased the bontech extruder to hopefully overpower the clog. Any thoughts on what to do?
When holding the bowden tube firmly in place, fit the little clip. This should prevent the bowden tube from moving and the gap opening.
If you don't have a clip, fit a tie wrap to keep the bowden fitting in the heat sink in its highest position.
