Duet 3 release date
@thebeachtoday Pre orders are open. See this post
Will there be a wifi version of Duet 3 soon? Then I could upgrade to Duet 3.
@roth said in Duet 3 release date:
Duet 3 is intended to be used with a Radspberry Pi (RPi) or other single board computer (SBC), although it can also be used in standalone mode using the built-in Ethernet port and SD card. The RPi provides both Ethernet and WiFi. So we don't plan to make a version of Duet 3 with WiFi on board.
With Ethernet I don't need a Raspi? Thats good to know
@CrazyCreator yep, although if you don't use the single board computer you will miss out on some of the future features like plugins that require the SBC to work.
Mhhhh ... Ok ... Thats not so good ... Raspi I come
@CrazyCreator said in Duet 3 release date:
No need to rush. Tony did say "future plugins". I must confess that although I have bought and fitted an RPi, I'm running "stand alone" because at the moment, I don't see any compelling reason why I should do otherwise.
