Issues with motors..... Don't move
@peirof said in Issues with motors..... Don't move:
M558 P8 I1 R0.4 F500 X0 Y0 Z0; M558 P8 I1 R1 F300 X0 Y0 Z0 H2 / M558 P5 I1 R0.4 F300 H5 X0 Y0 Z0 T2400
I could be way of the mark here but in this line
M558 P8 I1 R0.4 F500 X0 Y0 Z0; M558 P8 I1 R1 F300 X0 Y0 Z0 H2 / M558 P5 I1 R0.4 F300 H5 X0 Y0 Z0 T2400is the semicolon directly after the Z0 ok or does it need a space in there?
Doug
i am not sure, but think this is not the problem, the printer has been working with these config.g, months....
Well....eeee, not, bad.
I have do the test i have comented, soft reset and with a new MicroSD, reinstall printer.... and the same.
ALL WORKS (HEATERS, TERMISTORS, ENDSTOPS, ZPROBE,....) MINUS STEPPERS MOTORS
Only rest, think, is test of drivers of Duet, think TMC2660, are working ok...
How can test this point?
Its strange that all drivers goes off at the same time. Why?
Something more to test?These look bad....
Now i have no ideas.....
@dc42, please HELP!!!!!!!!!!!!!!
Please verify the following:
When you power up the Duet, initially it is possible to move the carriages of your printer by hand (slowly!), because the motors are not energised.
If you send the following commands:
G91
G1 S2 X-10then the X motor does not move.
After sending those commands, the X carriage is difficult to move (because there is current in the X motor). But the Y and Z carriages are still easy to move.
Sending this;
G91
G1 S2 Y-10doesn't make the Y motor move, but does lock the Y motor.
- Sending this;
G91
G1 S2 Z-10doesn't make the Z motor move, but does lock the Z motor.
- After sending these commands, there are no error messages reported in the GCode console.
Is all of that correct?
No, it is not correct.
The motors ever, after send the gcode (G1 S2 X-10 or G1 S2 Y-10 or G1 S2 Z-10), are smooth to move, are not energiced....
In that case, I think there may be a problem with the ENN signal that goes from the processor to all the drivers. This signal is also present on the expansion connector (see the label underneath for which pin it is). You could measure the voltage between it and ground (which you can connect to on any endstop connector) using a multimeter. With USB power only applied, it should be at +3.3V. When VIN power is applied, it should drop to 0V, which enables the drivers.
If I did not understand wrong, the procedure would be:
1- Disconnect, Duet3d Board, from power.
2- Connect Duet3d, with the USB cable to a PC.
3- I check the voltage, in the expansion module, between the pins, pin 28 (ENN) and pin 2 (GND).
4- With Duet3d Board, WITHOUT ELECTRIC CURRENT but with the USB connected, the reading on the voltage meter would have to be 3.3V.
5- I turn on the PSU, as soon as I turn it on, the voltage should drop to 0.0V.Okay?
tests do its.... i send images.
ONLY WITH USB TO LAPTOP
WITH TLM PSU ON
Something its wrong. No?. But what.... and.... WHY?
Some tips for I can do?
What did you mean by this in your earlier response:
i send by console G91 and after G1 S2 X10.... and axis stiff, the same with Y and Z
I unerstood that to mean that after you sent G1 S2 X10, the axis became harder to move by hand. But more recently you said:
Which is correct?
Is this Duet still within the warranty period? (as of when you first reported this issue).
The axis are smooth... Its easy move(after command move it)... Sorry for my english, Its not very good
@dc42 said in Issues with motors..... Don't move:
hi,
this is complicated....
The first time I bought the Duet board, it was this:
Order ID: 1957
Date Added: 10/08/2017and, in the middle of last year, it was changed, by a Duet 2 board, since the original, stopped working. The exact date I can not find it.
And this second unit is the one that has stopped working.
SUMMARY:
- The original purchase was made on 10/8/2017
- The current unit, installed in the middle of last year, I can not find the date
Please... i am waiting instructions
What can i do?
Well....
I think, Duet 2 its dead.... i d'like buy another board.... but i have some questions:
- I have see, there is a Spanish retailer, BricoGeek. The product in the retailer its Duet Wifi, but the specifications seems DUET 2 Wifi. Can anyone check this? What model its.
- I suppose, that i buy the board in these retailer, BricoGeek, follow using the official support and use of this forum.
- In the e-shop, the image seems have 2 fuse in board, my actual Duet2, only have one. Why? (In web refer as 1.04 version)
- And the most important.... WHY MY ACTUAL DUET, its partial dead. If i dont know why its dead,... there is a lot of possibilities that the new unit deads again for the same problem......
Duet WiFi and Duet 2 WiFi are the same thing. We added the 2 to distinguish the Duet WiFi/Ethernet/Maestro from the generation 1 boards (Duet 06, Duet 085).
In line with our policy of continuous improvement, we've gone through several PCB revisions to make minor improvements, to better work with evolving usage patterns. See https://duet3d.dozuki.com/Wiki/Hardware_Overview#Section_PCB_revision_history for the details.
Your Duet is well out of warranty, but if you want to send it to me then I will attempt to diagnose the fault, tell you what I think may have caused it, and see if a repair is possible.
For test purposes....
With only a USB wire conected... Duet its capable of move stepper motors? Or need a 24v Psu conected?
Hi
One doubt... In Duet 2,rev 1 03.... Fuse in board. What components protect?
While I was packing the Duet 2 plate (rev 1.3) for send us, I think I've seen the problem ..... I do not know how I have not noticed before, because it seems VERY obvious.
The E0 driver is burned ...
Now the theme is to know why, so as not to repeat it.
Any idea why?
If you do not tell me otherwise, upon discovering this evidence, I will send you the plaque tomorrow morning.
That explains why the E0 driver isn't working, but not the issue with the other motors. When your board arrives, I'll look at why the other motors don't move.
See my response to your other post for how to avoid blowing drivers.
Have you examined boars
