Problem printing circles
I actually just ordered Wantai 42BYGHM810
It was on my to do list, so...
Then I just need 24V power supply and Anet A8 will be no more.My motors are rated 1680mA, not sure if that is correct. And I had them running, at 1400mA and the circles were not great. But they heated up over 80°C So I stopped that.
And at the moment I am printing a puzzle box for a gift, it has mostly straight lines, so the circles are not a problem.
So, with Wantai motors the circles are circles. So either the stepper for X or Y was bad or the 0,9° vs 1,8° makes the difference. Or it was something else that I did not see and was fixed on reassembly. But I did that before the stepper change and there was no difference.
Motors are also quieter and cooler (both around 5 down).The only thing left is to figure out what to do with the old electronics and steppers. I might need another printer.
Q: What AWG wires do I need for the steppers? I will need to clean the wiring now.
@obeliks said in Problem printing circles:
I started rewiring now and will use 0.5mm² or 20 AWG for the wiring of my steppers. But you have to get wires with rather thin insulation to still fit into the Molex KK crimps. I use LiYY 4x0.5mm² cable for this.
20awg is rather thick. I suggest 22 awg, or 24awg for lower current motors.
I have 2.4A motors, so 22AWG?
Yes, 22awg is suitable.
@dc42 Is there any reason not to use 20AWG except for the stiffness of the cable if it needs to move?
@dc42 thank you
20awg should be OK, the crimp pins we supply are intended for 20 to 24awg.
