Cant get my nozzle close to bed at all when trying to print
I think the problem is that you are supplying USB power only, and when the WiFi module tries to connect, your USB power source is cutting out because of the increased current demand.
It happens when i have my 12v power on too i can send it with the power supply on.
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta1(RTOS) running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DDM-9FAM2-LW4S4-6J9D8-3SD6J-T3S7X
Used output buffers: 1 of 20 (1 max)
Static ram: 28452
Dynamic ram: 95912 of which 0 recycled
Exception stack ram used: 300
Never used ram: 6408
Tasks: NETWORK(ready,1408) HEAT(blocked,1256) MAIN(running,3628)
Mutexes: FilamentSensors(null) DHT(null) WiFi(null) TelnetGCodeReply(null) HttpGCodeReply(null) Telnet(null) HTTP(null) SD1(null) SD0(null) DirSearch(null) FileSystem(null) Aux(null) USB(null) MessageBox(null) ToolList(null) SPI(null) Malloc(null) NetworkGCodeInput(null) NetworkGCodeInput(null) FileInfoParser(null)
Last reset 00:00:37 ago, cause: power up
Last software reset details not available
Error status: 0
Free file entries: 10
MCU temperature: min 44.6, current 67.1, max 67.1
Supply voltage: min 12.3, current 12.4, max 12.5, under voltage events: 0, over voltage events: 0
Driver 5: standstill, SG min/max not available
Driver 6: standstill, SG min/max not available
Driver 7: standstill, SG min/max not available
Driver 8: standstill, SG min/max not available
Driver 9: standstill, SG min/max not available
Expansion motor(s) stall indication: no
Slowest loop: 1.09ms; fastest: 0.07ms
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Scheduled moves: 0, completed moves: 0
Bed compensation in use: mesh
Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 14.21ms; fastest: 0.01ms
HTTP sessions: 0 of 8- WiFi -
Network state is running
WiFi firmware version 1.21
WiFi MAC address 60:01:94:73:5a:d2
WiFi Vcc 3.17, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 17184
WiFi IP address 192.168.1.10
WiFi signal strength -62dBm, reconnections 0, sleep mode modem
=== Expansion ===
DueX I2C errors 0
- WiFi -
@puppet172 said in Cant get my nozzle close to bed at all when trying to print:
MCU temperature: min 136.1, current 136.8, max 138.1
This is worrying. can you confirm you have nothing plugged into the Duet other than the USB/12V power. That temperature, if it continued to rise, would cause the MCU thermal protection to kick in.
@puppet172, is the main processor chip really getting hot?
The wifi chip is definitly hot. the main chip on the board is warm but its not hot like the Wifi Chip -
Is the 3.3V regulator chip U2 also getting hot?
Where is that located? -
@T3P3Tony
I have motors and ends stops and a hotend and just some regular 3d printing stuff but thats the only stuff plugged into the board. -
Where is that located?Its this one:
Can you try with nothing plugged in other than USB.
@t3p3tony
Yes just give me a couple min to unplug everything and im going to check if it gets hot one everything is unplugged -
If you comment out the M552 command in config.g so that the WiFi module stays disabled, does everything remain cool and does YAT remain connected? If so then perhaps just the WiFi module is faulty.
the wifi module gets warm even when commented out but it still disconnects it seems when ever i send a command and then after a while of sittin there it will time out on its own and just disconnect -
@puppet172 thanks for the report. can you monitor the MCU temperature (repeated M122 calls over YAT). with just USB plugged in.
@puppet172 yes, please contact who you bought the board from and reference this thread.
