Berd-Air pump configuration notes for Duet users
About the noise your are talking about, is it the PWM frequency you can ear, and so it disappear at 20kHz, or is it something else?
Schottky rectifiers are more suitable for low voltage applications. Its not always the best choice because its prone to thermal runaway if its not heat sinked properly. The reverse leakage increases exponentially with temperature so it needs to be designed properly for thermal dissipation.
The preferred diode is a fast rectifier with a low forward and recovery time. There are many different types available. There SMD and also leaded parts so it depends on your application.
Hi
Im thinking of using the Berd Air concept from components I have laying around - what is the OD/ID of the metal pipe? is it stainless? thanks!
Standard tubing used by berdair are 3/32" OD aluminium tube.
I've personnaly switch to soft brass tube of 1/8" OD (Wall: .014") from K&S. Used a wire in the tube to bend it (honestly it's almost mandatory for larger tube) and solder the end instead of pinched it.
I don't recommend stainless tube if you want to make a tube ring with 12mm ID, because it already not so easy with softer material.
If you go over 3/32" it "may" require makerbot type nozzle which has 8mm clearance compare to 5mm clearance from E3D nozzle type, mostly for convenience especially if you use a headblock sock.
@dc42 said in Berd-Air pump configuration notes for Duet users:
I guess that pump doesn't draw enough current to heat the thermistor up. There is probably another thermistor in a smaller size that would work. I'll order a few different types and test them.
did you have a chance to test other thermistors ?
what will be your final recommendation for DuetWiFi board 1.03+ ?
should i add any electronic components or i can safely directly connect the 24v pump to fan output of the duet board?thanks!
I'm sorry, I haven't tested other thermistors yet.
If the DC resistance of the 24V air pump is less than about 7 ohms then you should use either a surge-suppression thermistor (or other surge reduction device) in series with it, or an external mosfet switch that can handle the surge current. You could try a 7 ohm resistor in series, but that may get rather hot and also limit the pump speed.
