New firmware 1.16 RC1
That's fantastic, thanks so much for your efforts!
I have reproduced this and fixed it. I intend to release rc2 later today or tomorrow.
After updating to RC1 my endstop E0 endstop for my Zprobe always says its triggered even if i reverse it.
M574 X1 Y2 S1 ; Reverse Microswitches
M574 E0 S0 ; Endstop for Zprobe on E0
M558 P4 X0 Y0 Z1 H4 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
G31 P600 X0 Y0 Z-1.1 ; Set Z probe trigger value, offset and trigger height -
I also notice that when editing the config file. after i save it , it no longer asks me to reset the Duet Wifi
what gcode command should i use to reset after editing codeM999?
G31 P600 X0 Y0 Z-1.1 ; Set Z probe trigger value, offset and trigger heightI confirm the issue. However, I was going to remove the E parameter from the M574 command anyway. You can use the I1 parameter on the M558 command instead.
Just hit emergency stop, does the same thing.
Emergency stop is working for me. However, I confirm that after editing config.g the latest DWC does not ask if I want to reset the Duet.
Is a reset always required or will some settings update immediatelyupon save?
Settings don't update immediately on save. However, with a few exceptions (e.g. network settings), you can send the modified gcode commands through the gcode console to have them take immediate effect. Or you can execute "M98 Pconfig.g".
I have just released 1.16rc2 so I am closing this thread.
