M997 not clear
I was on 3.5.4 SBC. I used M997 to switch to unstable feed. Then I issued M997 S2 and it churned for a while and came back still at 3.5.4. I was expecting it to update to the latest unstable.
When I used M997 with explicit version then it worked. So I'm not clear what M997 without a version is actually doing. Does it only work on stable feed if there is a new stable release?
Request:
Would like to issue M997 Q [for query] and it would report if there is an action that will be taken. Also show the feed status.
Examples:
"[STABLE]: current 3.5.4, nothing available"
or
"[UNSTABLE] current: 3.6.0-beta.3, available: 3.6.0-beta.4" -
@jltx how old is your pi image? If it's an older one then M997 S2 etc won't be supported
@jay_s_uk It was the latest 3.5.4 when I got it last week.
@jltx what command worked? M997 S2 V<version> ?
@T3P3Tony Yes, I used the V parameter as you show. And I assume the prior F parameter worked or it would not have found the 3.6 beta files that I specified.
undefined T3P3Tony moved this topic from Firmware installation
