Adding a Creality CR Touch.... Duet2 Wifi
I'm connecting a Creality CR Touch and reading the documentation on the Duet website. The following is correct for the wire color coding, but I'm confused with the actual connection to the Duet.
The documentation shows Red is 5+ but the Creality pinout says "Black" is 5+, which is correct? Should I be following the above screenshot and wire Black to 5+, that just seems wrong to me...VB,
@vbtalent2 match the wires that are on the Bl touch, if the BL says Red is +5 then that will go to the +5 on the Duet board. Color may be different. You just need to make the wires correspond to the correct +5, ground, ect.....
Also the two ground wires can be connected together
Thanks for the reply...
I think you're telling me that this is incorrect?
and I should follow this
What does the documentation from Creality say about your probes wire pinout? Trust that, and match the description to the pin name for the Duet. Color can't be trusted because Creality seems to use whatever wire bundles they can source and the color coding is haphazard at best.
@vbtalent2 do you have it working now?
@dc42 Yes I do, thank you for checking.
Running into a couple of other smaller issues but I'm thinking its all config related.. I'll follow up with a new thread.
VB,
