Filament runnout sensor
https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_filament
"Note that filament monitoring in RRF is only active when printing from SD card."
Does that mean SD card OR from SBC, or when using a Duet with a SBC does the filament runnout sensors cease to function?
@DocTrucker that means when printing from the sd card in duet or from the SBC attached to the duet when in SBC mode
@jay_s_uk cheers.
@DocTrucker Thanks for pointing this out. I've changed it to this, which is hopefully clearer:
enable filament monitoring when printing a file from SD card, in standalone or SBC mode.
SBC mode still has the same SD card structure, as a 'virtual' SD card. And it is still stored on the SD card (in the RPi) in SBC mode.
@droftarts I maybe moving it off the SD card in the near future. I don't believe the RPi's treat SD cards differently to any other storage. I think it means if you run gcode outside of a build/print process the endstops don't work? Perhaps macros are in a bit of no-mans land there?!
