Filament runnout sensor
https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_filament
"Note that filament monitoring in RRF is only active when printing from SD card."
Does that mean SD card OR from SBC, or when using a Duet with a SBC does the filament runnout sensors cease to function?
undefined DocTrucker marked this topic as a question
@DocTrucker that means when printing from the sd card in duet or from the SBC attached to the duet when in SBC mode
undefined DocTrucker has marked this topic as solved
@jay_s_uk cheers.
@DocTrucker Thanks for pointing this out. I've changed it to this, which is hopefully clearer:
enable filament monitoring when printing a file from SD card, in standalone or SBC mode.
SBC mode still has the same SD card structure, as a 'virtual' SD card. And it is still stored on the SD card (in the RPi) in SBC mode.
@droftarts I maybe moving it off the SD card in the near future. I don't believe the RPi's treat SD cards differently to any other storage. I think it means if you run gcode outside of a build/print process the endstops don't work? Perhaps macros are in a bit of no-mans land there?!
