Emergency Push Button activates on both condition
@SANJR Better still, use it as it for it's intended purpose. I use the same switch but connect the 24V from the PSU to one side and the board(s) Vin to the other. Banging the switch cuts all power to the boards.
Alternatively (and arguably better still) run the mains positive to one side and then connect the PSU mains in to the other. That'll kill all power. (I can't do that on my machine because my battery UPS will cut in and supply 24V in case of mains failure).
@droftarts Hi
The Wiring on the emergency is coonected to the NC on the emergency pushbutton. (Image shown below) and is connected to 1o6.in and GND of the io6.in pin.
The config.g. file for the same is
M950 J1 C"io6.in"
M581 P1 T0 S1 R0 -
@SANJR As it is (I think) a simple 'connected' or 'disconnected' switch, I'd guess (like @fcwilt suggested) it is 'bouncing' when the switch is reset, at least enough to trigger again.
You can get around this by creating a trigger, using Meta Gcode, which tests the switch a second time shortly after the first press (perhaps 0.25 seconds later) to see if it is still pressed, and either continues with the emergency stop, or if it detects a false trigger, carries on. I think there's an example on the forum somewhere, but I can't find it just at the moment.
Create your input with something like this
Change to suit how you want trigger to workM950 J0 C"exp.e5stop" M581 T2 P0 R0 S0
Create a trigger macro associated with the switch.
Note that by default if you attach your switch to trigger 0 it will do an estop.
I don't know if you can create a trigger0.g file to do the debouncing code.
Then use something like this;trigger2.g G4 P10 ; delay 10ms to debounce if sensors.gpIn[0].value = 0 echo "switch bounce detected - exit macro" M99 ; break out if sensor value is zero again (bouncing) ;we got to here so do an estop and restart M112 M999
I think (but my thinker may be losing it) that the T0 trigger is active during moves where the T2+ triggers are only active "between" moves.
@fcwilt said in Emergency Push Button activates on both condition:
You could be right. I've never tested.
I only use a trigger for a filament sensor so it's neither here nor there
If it were me I'd wire the switch to the 24v supply -
Trigger 0 does an emergency stop. Trigger 1 does a pause. T2 upwards runs the associated macro. In addition R0 will allow the trigger to run at any time, R1 will only allow it to run when printing from the SD card, and R2 only when not printing.
@OwenD, @deckingman, @fcwilt & @droftarts Thanks
As recommended i would modify the confi.g file and create a macro file. Also shall i create a two condition the first condition when the switch triggered from S1-high to low state with T0 parameter no trigger file required.
M950 J1 C"io6.in" ; Configure pin J1 as input and assign input pin "io6.in"
M581 P1 T0 S1 R0 ; Setup Pin 1 when trigger occurs S1 from High to Low State during any time R0 for Emergemcy Push Button, no trigger.g neededAnd a second condition for the same io6.in but triggered from low to high state with T2 parameter and tigger2.g macro file
M581 P1 T2 S0 R0 ; Setup Pin 1 when trigger occurs S0 from Low to High State during any time R0 for Emergemcy Push Button, trigger2.g neededIn the trigger2.g macro file the meta command as suggested previously
;trigger2.g
M112
M999Is this way possible for a same pin two condition of trigger ¨S¨and different ¨T¨parameter?
@SANJR said in Emergency Push Button activates on both condition:
................................ M950 J1 C"io6.in" ; Configure pin J1 as input and assign input pin "io6.in"
M581 P1 T2 S0 R0 ; Setup Pin 1 when trigger occurs S0 from Low to High State during any time R0 for Emergemcy Push Button, trigger2.g needed..................................Is this way possible for a same pin two condition of trigger ¨S¨and different ¨T¨parameter?
Yes, but you only need one M950 command.
So.....
M950 J1 C"io6.in" M581 P1 T0 S1 R0 M581 P1 T2 S0 R0
Thanks for the feedback
