define an analog input?
Hello ,
I have a question. How can I define an analog input? For example, it should switch when 3.2 volts are reached?
Is there a solution ?
@Zseven AD conversion uses lots of interrupts and can disturb the printers main tasks.
I recommend using a separate AD-converter (e.g. ESP32) and communicate via digital trigger input with the Duet. -
@o_lampe
Hello ,but is that basically possible ?
@Zseven Which Duet board? The capabilities of each pin are listed in the wiki page for each board. I think you have a Duet 3 mainboard 6XD? If so, see: https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6XD_Hardware_Overview#inputoutput-port-capabilities
From that, you can see analogue input is supported on io3.in to io8.in. The inputs will tolerate up to 30V and have 10K series resistors. You also have differential signal, opto-isolated inputs for io5.in to io8.in, rated to 30V. Use M950 with the J parameter to define an input, see https://docs.duet3d.com/en/User_manual/Reference/Gcodes#configuration-examples-and-notes
Once the signal is connected to the Duet, what do you want to do with it? If you want it to trigger on a high input, you can set up a trigger to do this. See https://docs.duet3d.com/en/User_manual/Tuning/Triggers
