Problem with XY shift in Z
Hello there,
I've built myself a tool changer with 3 lead screws on Z. So far pretty much anything is working perfectly but i have a problem with a shift in Z.
The alignment of lead screws and linear rails on Z is almost perfect so they shouldn't be the problem. Ive narrowed down the problem to software bc i noticed that sometimes when i move z after homing x and y also move- even tho they're not supposed to.
Im using a Duet 3 6HC in standalone mode alongside an expansion 3HC, both are updated to the newest non Beta version.
Please excuse my crude config.g file, its still a prototype and its my first Printer.
And please excuse my english, its not my first language & thank u in advance!!!; Configuration file for Duet 3 (firmware version 3.3) ; ; ; Grundstruktur vom Tue Feb 01 2022 17:37:07 GMT+0100 (CET) ; Allgemein G21 ; Einheit [mm] G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"PrinterX" ; Drucker Name M669 K1 ; CoreXY Modus ; Netzwerkeinstellungen M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Antriebe M584 X0.3 M584 Y0.4 M584 Z0.1:0.2:0.0 M584 C1.0 M584 E0.5 ;M574 Z2 S1 P"io5.in+io4.in+io7.in" ; Z axis with two motors, individual min endstops, active high ;Acceleometer ;M955 P0 I16 C"spi.cs3+spi.cs2" ; all wires connected to temp DB connector M569 P0.3 S1 ; X (0.3) Richtung M569 P0.4 S1 ; Y (0.4) Richtung M569 P0.0 S0 ; Z1 (0.0) Richtung M569 P0.1 S0 ; Z2 (0.1) Richtung M569 P0.2 S0 ; Z3 (0.2) Richtung M569 P0.5 S0 ; E1 (0.5) Richtung M569 P1.0 S0 ; C (1.0) Richtung ; Achsensetup M208 X0:320 Y0:290 Z0:270 C-45:360 ; Achsen Maxima & Minima M92 X160.00 Y160.00 Z800.00 C91.022 E657 ; Schritte in mm ; Microstepping M350 X16 Y16 Z16 E16 I1 ; Microstepping mit Interpolation für XYZ E M350 C16 I10 ; Microstepping mit Interpolation Für C ; Motorensetup M566 X900.00 Y900.00 Z600.00 E300.00 C2 ; set maximum instantaneous speed changes [mm/min] M203 X6000.00 Y6000.00 Z1800.00 E7200 C5000 ; maximale Geschwindigkeit [mm/min] M201 X500.00 Y500.00 Z200.00 E8000 C500 ; maximale Beschleunigung [mm/s^2] M906 X800 Y800 Z800 I30 ; Motorampere [mA] und Ruhezustand mA [%] M906 E1200 C400 I10 M84 S30 ; Motoren Ruhezustand [s] ; Achsen Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X320 Y290 Z270 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io5.in" ; Endstop X Achse low End M574 Y1 S1 P"io7.in" ; Endstop Y Achse low End ; Z-Probe M558 P8 C"io0.in" H3 F360 I0 T20000 ; Set Z probe type to switch, the axes for which it is used and the dive G31 P200 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height M557 X20:300 Y25:290 S40 ; define mesh grid M671 X160:345:-40 Y-30:327:327 S5 ; leadscrews M557 P1 X125 Y70 M557 P2 X10 Y270 M557 P3 X290 Y270 ; Thermistoren M308 S0 P"temp0" Y"thermistor" A"Bett" T100000 B4138 ; Sensor 0 als Thermistor an temp0 M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.196220e-7 H5 ; Sensor 1 als Thermistor an temp1 ; Heizbett M950 H0 C"out2" T0 ; an (out2) Thermistor (T0) M307 H0 B0 S1.00 ; Bang Bang Modus & PWM limit M140 H0 ; Heizbett als heater 0 M143 H0 S120 ; Temperatur Limit für heater 0 zu 120C ; Hotend M950 H1 C"out1" T1 ; an (out1) Thermistor (T1) M307 H1 B0 S1.00 ; PID Modus for heater 1 & PWM limit M143 H1 S280 ; Temperatur Limit für heater 1 zu 280C ; tool 1 Lüfter M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency M106 P0 C"Hotend cooling" S1 H1 T50 ; set fan 0 name and value. Thermostatic control is turned on Lüfter M950 F1 C"out8" ; create fan 1 on pin out8 and set its frequency M106 P1 C"Part cooling" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off ; Test Expansion mit Lüfter M950 F2 C"1.out8" Q500 M106 P2 C"TEST" S0 H-1 ; Tools M563 P0 D0 S"Mosquito" H1 F1 ; define tool 0 M98 P"/sys/Tool_offsets.g" G10 P0 R100 S230 ; set initial tool 0 active and standby temperatures ; Custom settings are not defined ; Miscellaneous M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss M501
@Wehaywire Please post your firmware version: send M115 and post response. Please also run
M98 P"config.g"
and post the response.I can see a few issues with your config.g. I'm not sure any of them would cause X and Y to move when Z only is commanded.
- You have two sets of M208 commands in your config. They are the same, so probably not a problem, just confusing if you change one and not the other.
- Remove the three M557 lines after your Z Probe configuration. They should be in bed.g.
- It is recommended to add the following to config.g, before any commands that reference any CAN bus connected expansion boards (ie before any M569 or M584 commands):
G4 S2 ; wait for expansion boards to start
- You have
in the Tools section. What commands are in that file?
undefined Wehaywire marked this topic as a question
undefined Wehaywire has marked this topic as solved
undefined Wehaywire has marked this topic as unsolved
@droftarts Thanks for the quick response.
the answer to M115 was:
M115 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet 3 MB6HC v1.01 FIRMWARE_DATE: 2022-11-30 19:35:23
the answer to M98 P"config.g"
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Error: Wrong number of values after '''X''', expected 2 Error: Wrong number of values after '''X''', expected 2 Error: Wrong number of values after '''X''', expected 2
the Tool_Offsets.g just contains a single command:
G10 P0 L2 Z-33.9 X5 Y-49 ;Tool 0
I tried that bc i wanted to have the different tool offsets in one file so i can change it easily if i make changes to the tools. Right now i only have one tool hence just the single command..
I also deleted the second M208 and put the M557 in the bed.g file, i also added the G4 S2 Command. -
undefined Wehaywire marked this topic as a regular topic
@Wehaywire said in Problem with XY shift in Z:
Can you show a video of what you mean?
Can you send M115 B1 so we can see the version of the 3hc.
Error: Wrong number of values after '''X''', expected 2Error: Wrong number of values after '''X''', expected 2Error: Wrong number of values after '''X''', expected 2
I'm not sure where these errors are coming from. You can try and narrow down where that is by adding some M117 commands to your config.g every few lines. Like M117 1 M117 2 M117 3 etc. That will echo the number. When the error occurs between two numbers you know where to look.
@Wehaywire please share your homex.g, homey.g and homeall.g files too. It's possible that you have set them up in a way that leaves X and/or Y outside the normal reachable range, in which case the first movement after homing will try to bring them into range.
