Firmware building
@dc42 Do you have some good ideas? Thank you very much.
@qingge I noticed that it says on one of your screen shots "Internal builder is used for the build". However, the settings in the project file are to use an external builder. So I guess you must have changed them.
@dc42 said in Firmware building:
的设置是使用
If i choose external builder, I can't choose CDT and I don't know what to do?
@qingge mine is set to Gnu Make Builder.
@dc42 Is it okay for me to set it up like this? thank you.
@qingge that's probably OK, however GNU Arm Eclipse is quite old now. I recently updated the build instructions at https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware to use MSYS2 instead.
