2 SD Cards - SBC - stop after pause.g 3.5beta2
Yes with SBC.
And yes, that putty command helps. Just used it first time. -
Let's see what @chrishamm has to say.
@IndeX4D @LuniLAB I am still unable to reproduce this and I'm afraid the diagnostics data provided so far is of little use. When the machine gets stuck, please send
M122
over the web UI before pressing E-STOP and share the output here. If that does not complete, tryM122 "DSF"
instead. In addition, a full debug log of DuetControlServer may help (i.e. with log level set to debug instead of the default info). See my previous post if you want to contribute logs that may help me track it down.If that is not an option, I suggest you revert to 3.4.5. See here for further information.
resurrect.g is normally not used by the resume process, AFAIK it's only used by the auto-save on power loss feature.
@chrishamm
I have to use 3.5 because of my closed loop stepper. The quality is mich better now, so I´ll switch between standalone for work and sbc for investigate.
I´ll do the next steps asap and tell the results. -
@chrishamm If you follow the thread, we don´t have to press EC-stop anymore.....
thats what I ment about a new thread. To messy here. Don´t wanna tell everything twice
