Invalid Height Map ...
Hello .. John G. here i have been out of the 3d-printer for some time and now trying to get me Creality CR-10 Pro S and i added a Duet3d bord to it all seems so be workling good other the Z offset. am soo set (I think ) and wanted to test the Height Map and see how bed was (We know Creality is never flat). Used a dial Indicator and have it close. tryed to put up the MAP and got this Error:
Invalid Height Map
Any help here do i need to update something
thanks and look forward to what you all comeup with -
@n3ovo Make sure your RepRapFirmware version matches DuetWebControl. Some old DWC versions do not support newer heightmap files.
thanks for the quick answer ... Can I ask 1 more thing of you, could you point me to the best versions for both the (7" screenDuet - Web Control) and the main board
I have loaded :
Web version I have running : Duet Web Control 3.1.1Board: Duet 2 Ethernet (2Ethernet)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.5beta2 (2023-02-08)Your help is supper helpfull just not that good at updateing to the newest. as you can see that is what got me stuck now
Thanks John G.
@n3ovo for now I suggest you use version 3.4.5 of everything. Downloading the zip file at https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.5 should do it.
I would suggest you stick to the latest stable release unless you need a specific fix from the beta or have a working system and want to do some testing.
It looks like your DWC version is out of sync with your firmware version.
To get back on track I suggest you upload this zip file to the system tab in DWC.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
Then check your versions afterwards to see if they match at 3.4.5
@n3ovo said in Invalid Height Map ...:
7" screen
For the PanelDue, see here: https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
You'll need to identify your paneldue version and get the correct firmware file for it.
