Filament retraction at the end of print
Hi Guys,
Need some help!
not sure why at the end of the print the filament retract automatically about a feet.
Thanks
John
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"JP" ; set printer name ; Network M552 S0 M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes forwards using default driver timings M569 P1 S0 ; physical drive 1 goes forwards using default driver timings M569 P2 S1 ; physical drive 2 goes forwards using default driver timings M569 P3 S0 ; physical drive 3 goes forwards using default driver timings M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X580 Y580 Z580 E650 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X230 Y230 Z250 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop ;M591 D0 P7 C"e0stop" S1 R50:130 L7.0 E10 ; BTT Smart Filament Sensor ;M591 D0 P1 S1 ; Filament runout Sensor ; Z-Probe Bltouch ;M950 S0 C"servo0" ; create servo pin 0 for BLTouch ;M558 P9 C"^probe" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds ;G31 P500 X-40 Y-10 Z2.95 ; set Z probe trigger value, offset and trigger height ;M557 X10:180 Y10:210 S40 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0 M301 P21.73 I1.54 D76.55 ; disable bang-bang mode for the bed heater and set PWM limit ;M307 H0 R2 D65 B1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M307 H0 A0.425 C0.506 D2.82 S0.50 V0.0 B0 ; NEW M140 H0 ; map heated bed to heater 0 M143 H0 S150 ; set temperature limit for heater 0 to 150C M143 H0 S150 ; set temperature limit for heater 0 to 150C M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; set temperature limit for heater 1 to 300C ; Fans M950 F0 C"fan0" Q1000 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q1000 ; create fan 1 on pin fan1 and set its frequency M106 P1 S0 H1 T60 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous ;M575 P1 S1 B57600 ; enable support for PanelDue M575 P1 S2 B57600 M552 S1 ; enable network M150 X2 T0 P0 ; jp MENU? M918 P1 E4 F1000000 ; BlTouch ; Z-Probe ;;M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch ;;M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds ;;G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height ;;M557 X15:215 Y15:195 S20 ; define mesh grid ; set Z probe type to bltouch and the dive height + speeds M558 P9 H5 F120 T6000 C"^probe" ; Setup Servo0 as servo port on SKR-RRF-E3 M950 S0 C"Servo0" G31 P550 X-40 Y-5 Z1.51 M557 X50:180 Y50:210 S40 ; Filament Sensor M591 D0 P1 S1
override
; config-override.g file generated in response to M500 at 2021-01-20 10:10 ; This is a system-generated file - do not edit ; Heater model parameters M307 H0 R2.429 C140.000:140.000 D5.50 S1.00 V0.0 B0 M307 H1 R2.429 C140.000:140.000 D5.50 S1.00 V0.0 B0 ; Workplace coordinates G10 L2 P1 X0.00 Y0.00 Z0.00 G10 L2 P2 X0.00 Y0.00 Z0.00 G10 L2 P3 X0.00 Y0.00 Z0.00 G10 L2 P4 X0.00 Y0.00 Z0.00 G10 L2 P5 X0.00 Y0.00 Z0.00 G10 L2 P6 X0.00 Y0.00 Z0.00 G10 L2 P7 X0.00 Y0.00 Z0.00 G10 L2 P8 X0.00 Y0.00 Z0.00 G10 L2 P9 X0.00 Y0.00 Z0.00 M486 T0M486 S-1
; homeall.g ; called to home all axes ; G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-240 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-240 Y-240 F360 ; move slowly to X and Y axis endstops once more (second pass) G90 ; JP ADDED G1 X150 Y150 ; JP ADDED G30 ; JP ADDED ;G90 ; absolute positioning ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ;JP COMMENTED G1 H1 Z-255 F360 ; move Z down stopping at the endstop ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
@john345463563 said in Filament retraction at the end of print:
It's likely you have a retraction move in your slicer end gcode section and the slicer is set to absolute extrusion mode, so when the retraction happens instead of retraction 1mm for example, it retracts back to the extruder position at 1mm of print progress. Set your slicer to relative extrusion, and that should take care of it, and/or add M83 to the start of your slicer end gcode before the retraction move to set it there at the least.
@Phaedrux said in Filament retraction at the end of print:
Thank you so much for looking into this.
Do you know I can I add M83 to CURA:
and not sure what need to add at the end.
Thank
John
In the cura settings bar, search for "relative". It should pop up Relative Extrusion checkbox under the Special Modes section. Enabling that should be enough.
@Phaedrux Thank you for your help!
I've enabled Relative Extrusion however the filament always retracts at the end of the print.
Wondering how to add the M83 commands to cura...
Thanks
John
Please copy and paste the end gcode that cura is using. You can find it in the printer settings window.
@john345463563 what do you have in your Cura settings for the GCode run at end of print?
@dc42 said in Filament retraction at the end of print:
Apologize, how do you check Cura settings for the GCode run at end of print?
Thank you!
John
Settings > Printers > Manage Printers > select your printer > Machine Settings
