tool 0 was not driven because its heater temperatures
I use a pellet extruder for my 3d printer hotend.
when I try to print, the heatbed and hotend have reached the proper temperature (for now I use 60 for the heatbed and 150 for the hot end). the print process is also running properly, but the e0 motor does not move, whereas on the duet web control on the extruder drives it shows the movement value and on the console there is a warning: tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault -
@ardisf use the M302 command either to enable cold extrusion or to reduce the minimum extrusion temperature.
@dc42 when trying to manually extrude e0 can move, but when it prints it doesn't move automatically
Are you using the M302 command to reduce the required print temp to below 150 in config.g?
This would need to be set every time you power cycle.
https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m302-allow-cold-extrudes
