[3.5b1+] Inaccurate print dimensions
@dc42 Yup, looks like it's only during probing. Shall I specifically add a M201.1 then to configure that? I would have expected it to use the normal defaults if no M201.1 is present?
@Diamondback yes, I suggest you add a M201.1 command for now.
I am thinking of changing M201.1 to take a percentage value of the normal acceleration in 3.5beta3 instead of an actual acceleration.
@dc42 Hmm, I wish I remebered which tool I printed the prints with issue with....
Two of my tools use extruders on a slave Mini 5 board while the other two tools are connected to the 6HC... Maybe it has to do with the extruders not being on the main board?I just went back to older builds (specifically the one where you fixed the Mini 5 Slave OoM error) and I can see hints of the issue appearing again when I use one of the tools with an extruder on the Mini 5. It's not as bad as before, but maybe other things play a role.
I'll keep experimenting...
