M600 - prevent power cut of motors
I want to use M600 in my slicer to make color changes with a single extruder.
It works flawless - if I am fast enough / close enough to the printer to do the change before "something" shuts down the motors and cuts the temperatures.What I do not know (and do not find information about) is this "something".
What script / service / ... is shutting down the heaters and motors after some time if "nothing happens"?
Can I change the behaviour? (E.g. motor shut down: NOOOO, bed shutdown: please not, extruder shutdown: yes).Thank you in advance!
@tak21 idle current reduction will reduce current to the motor after 30 seconds by default. However, if the heaters are shutting down, that must be something else. Does your filament-change.g file if you have one, or your pause.g file if you don't, turn heaters off?
Can you share your config.g and pause.g or filament-change.g file? Can you also share your firmware version?
@Phaedrux
config.g
pause.g
filament-change.g
03-Change_Filament.txtDuet Web Control 3.4.4
RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.4@all: From your reactions I assume, that this is not a standard behaviour. As I used - as a base a configuration - a Caribou3d 320 config including macros I will now search for a macro / service which is not comming ootb and triggers this behaviour.
Question please: if I would want to implement a "shut down the heaters if nothing happens for some time", where would I start to implement it?
@chrishamm I think I did not configure this as the documentation says: do not use it.
@tak21 said in M600 - prevent power cut of motors:
In daemon.g
@dc42 Thank you! I found it
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
