Classic typo - M929
https://docs.duet3d.com/User_manual/Reference/Gcodes#m929-startstop-event-logging-to-sd-card
I strongly suspect "Starting with RepRapFirmware 3.2.0-beta3 there is a more fine granular logging available that is not split into 3 log levels" really intends to be "... is now split into 3 log levels". (I'd also delete the 'fine', which is a bit tautological, but that's less important.)
A little further down I expect the log level "DEGUG" should read "DEBUG".
@achrn thanks for pointing this out. I have corrected it.
@dc42 I tweaked the description a bit, as it was a little tautological, to:
From RepRapFirmware 3.2.0 and later, more granular logging is available. There are three log levels, and no logging. When logging is enabled, each line in the log will have the log level of that message added after the timestamp.
