usb dwc
I cannot connect to the wifi in my duet2 wifi. noticed moderator's remark:
"You can run the Duet via USB too if you want, but you will lose the power of the web interface"
kindly explain how. thanks! -
@oolyk see https://docs.duet3d.com/How_to_guides/Getting_connected/Getting_connected_to_your_Duet for how to get started using USB. Once you have a working USB connection, you should find it easier to get the network connection working.
@dc42 , thanks.
I am totally stuck. my paneldue turned dead a year ago and I have since been using wifi dwc but now wifi disappeared as well. cannot manage to have the network being recognized.
what can I do under these conditions to find the problem of the paneldue ?thanks.
For the PanelDue try updating the firmware
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDueFor the loss of wifi, follow the link posted above by DC42 on how to get connected to your duet. It goes through using a USB connection and terminal software to send commands to the Duet. If that doesn't work, I suggest you look at this link and let us know how far you get in testing it.
https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
@phaedrux. thanks.
I am trying to follow "activate and connect......when it doesn't work"
I check the sd card in the computer and it has all the files, including SetNetwork. however, when I command m98P/macros/SetNetwork, it comes back with "could not find..." . tried other macros files with same results. how can I check the card thru YAT? -
