Input shaping
anyone have knows a comprehensive guide to use accelerometer for input shaping. I have a be flinger and it should be a little more difficult to do input shaping on it. my mind is a pretzel after reading M956 command. I don't know what should be P value and S value. I know you need LIS3DH which I purchased and its on the way. I don't know if I should make .csv file for each axis and how firmware make use of those files. or should I call them anywhere in config. I will appreciate any help.
@sinole it's also possible to determine the main ringing frequencies by measuring the ringing spacing in mm on a print, and dividing that into the print speed in mm/sec.
@dc42 I have seen a stl that supposed to show ringing. seemed very long process. which method is more effective in your opinion?
