M500 (case 500:) in the firmware not executed
Hoi,
I'm sending M500, but the following code is not executed:can someone help me?
Thanks -
What firmware version are you using?
Where are you sending M500?
Why do you say it's not working?
Does sending M500 create a config-override.g file in the sys folder if one is absent? -
@phaedrux thanks for your response. It is version 3.3. I send it from the webinterface.
when i send it from the webinterface the config-override.g is created no problem.
But i think the webduetcontroller handles the M500, not the firmware RepRaoFirmware.
Because (case 500 code is not executed) when i send M500 from the webinterface. -
@mohamed are you running in standalone mode or with attached SBC ?
@dc42 With attached SBC. I see now that the version 3.4 is working. If i send M500 from webinterface the code case 500: is excecuting.
@mohamed prior in older firmware versions, DSF code on the SBC implemented M500. More recently we introduced a mechanism for RRF to write files on the SBC, so that approach was no longer necessary
@dc42 Thanks for the info. I think my question is answered.
