Part fan runs at max on reboot
I have a part fan just installed on out4. For some reason, on reboot Duet runs it at max speed for a few seconds. Is there a way to leave the part fan off by default on reboot?
config.g for this fan:
M950 F0 C"!out4+out4.tach" Q25000 M106 P0 C"part-cooling" S0 H-1
full config.g
; Configuration file for Duet 3 (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Feb 01 2022 16:47:18 GMT-0600 (Central Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"duet3" ; set printer name ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S0 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes backwards M569 P0.3 S0 ; physical drive 0.3 goes forwards M569 P0.4 S0 ; physical drive 0.4 goes backwards M569 P0.5 S1 ; physical drive 0.5 goes forwards M584 X0.0 Y0.1 Z0.2:0.3 E0.4:0.5 ; set drive mapping M350 X32 Y32 Z32 E64:64 I0 ; configure microstepping without interpolation M92 X160.00 Y160.00 Z1600.00 E1660:1660.00 ; set steps per mm M566 X1500 Y1500 Z180.00 E400.00:400.00 ; set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z2000.00 E1200.00:1200.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z100.00 E500.00:500.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X350 Y350 Z400 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in ; Z-Probe M950 S0 C"io7.out" ; create servo pin 0 for BLTouch M280 P0 S60 M558 P9 C"io7.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-44 Y-9 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X50:300 Y50:300 S20 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B4092 ; configure sensor 0 as thermistor on pin temp3 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S100 ; set temperature limit for heater 0 to 80C M308 S1 P"temp1" Y"thermistor" A"T1 ExtLeft" T100000 B4685 C6.519681e-8 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C M308 S2 P"temp2" Y"thermistor" A"T2 ExtRight" T100000 B4685 C6.519681e-8 ; configure sensor 2 as thermistor on pin temp2 M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H2 S280 ; set temperature limit for heater 2 to 280C ; Fans ;M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency ;M106 P0 C"part-cooling" S0.65 H-1 ; set fan 0 name and value. Thermostatic control is turned off M950 F0 C"!out4+out4.tach" Q25000 M106 P0 C"part-cooling" S0 H-1 M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency M106 P1 C"hotend1L" S1.0 H1:2 T45 ; set fan 1 name and value. Thermostatic control is turned on M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency M106 P2 C"hotend2R" S1.0 H1:2 T45 ; set fan 2 name and value. Thermostatic control is turned on ; Tools M563 P1 D0 H1 F1 f2 ; define tool 1 G10 P1 X-7 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C M563 P2 D1 H2 F1 F2 ; define tool 2 G10 P2 X7 Y0 Z0 ; set tool 2 axis offsets G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C ; Custom settings M929 S3 ; enable logging ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S12 R20 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
@seventhwhiskey that's pretty normal when the firmware isn't loaded just in case the fan is being used to power a hotend cooling fan to prevent blockages
@jay_s_uk That's about what I thought was going on, but is there any way to change that? I'm running a high-flow centrifugal blower and at 100% it's... a lot...
To which outputs does that apply, or is it just for fans as defined in config.g? I have plans for some of the other outs that must not be powered on startup, even for a few seconds.
@seventhwhiskey An untested long shot would be to put a G4 delay of a couple of seconds at the end of your config.g then move the M106 and possibly the M950 for that fan, after that delay. I'm not sure what order things happen on boot but it might work.
@seventhwhiskey I can't remember if it's all fan outputs I'm afraid. There will probably be a way of overriding it using an extra pull up or pull down resistor but electronics isn't my specialty
@jay_s_uk this is inevitable when using 4-wire fans, given that those fan outputs are not dedicated to 4-wire fans but can support 2-wire fans, SSRs etc. as well. The best you can do is to configure the fan early in config.g.
Finally got around to testing this again. Moving fan definitions to the beginning of config.g reduces the "fan 100%" time to about 1.5 seconds when rebooting, which is somewhat better but won't be acceptable for non-fan items. On power loss it's more like 10-15 seconds while everything boots. G4 delay doesn't make a difference since the outputs are powered before config.g is processed.
Seems like this is baked into the board, so I'll probably need to come up with a hardware solution.
Thanks
@seventhwhiskey one other option would be to provide an external 5V supply and turn on the 24v via the PS_ON pin and a relay.
That way the config will be run before there is 24V to spin the fan.
Other benefit is the Duet can shut down the PSU if it detects any heater faults
