Thermistor 2000C
Hello Gentlemen,
I would like to ask you for help. I purchased my first Duet 3 mini 5+ wifi and have problem with thermistors (E3D blue one 100k). I have all reading on them 2000C no matter if they are plugged or not. I'm trying to fix this for more than 2 weeks
. Any suggestions ?
Hereby some info from machine:
Config
M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1
M308 S1 P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp2
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0CFW:
RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode). -
@ivan_sk Usually caused by: Bad conection, Bad wiring, Bad thermister. Use a multimeter to check the resistance.
what resistance should I check?
Thermistor is 100k with multimeter. Thermistor with extended cable is 100k, is connected to temp2 / temp 1 port. -
If you send M98 P"config.g" do you get any errors?
2000c very likely means the thermistor isn't actually making a connection to the board, so triple check the wiring.
@ivan_sk please run the following commands with no extra parameters, from the DWC prompt (or from USB if you don't yet have DWC running) and report the responses:
M308 S1
M308 S2They should report the type of the last error seen when reading the thermistors.
@phaedrux said in Thermistor 2000C:
Heres report. Is there any way how to check if temp_0 to temp_2 works? Can I measure them or something?
@ivan_sk Could you please unplug both thermistors from the Duet and measure the resistance between the two (mostly) black lines, then, between the red lines? Maybe there's some connection?
@ivan_sk said in Thermistor 2000C:
Red - Red. 6,9k Ohm
Black - Black. 6,9k OhmSorry, I meant to measure the cabling, not the board …
Thanks. Do you get that response when nothing is connected to any of the three TEMP inputs? If so, then you board is faulty and you should submit a warranty claim to warranty@duet3d.com.
@infiniteloop
oh sry, but that are two separated thermistors. I already measured them separately. There are no connection between black - black and red - red. Its genuine e3d thermistor with cable. -
Thanks. I just wanted to exclude common ground in head or lines.
Thank you for feedback. This is report without any temp inputs connected.
Iam afraid of submit a warranty claim because I accidentally broke part of small plastic pin as you can see in previous photo of board (temp_0 pin).
@ivan_sk if there's no other damage, we will still accept your warranty claim.
Please accept my deepest thanks
