Smart effector lost nearly all sensivity
Yesterday i finished a flawless print..wanted to start another one ( workked so flawless that not even watched it start to print)and then it happens..nozzle clogged because ther were no z-offset.
After lots of G32 and MEshs i started over with the testing of the smart effector. Afterall i found that it losts its sensitivity.just between 2 prints. on standard of 50 it dont flashed if i tap the nozzle...and it rams the nozzle into bed till i lost steps and scratches over the print bed.
Had tutn up the sensivity up to 15 to get a halfway normal feedbeach via M672 S105:010:245 but even with that it often ignores the contact...
Disassambled the effector today but cant see anything on the PCB. Any hint of what could cuase this? worked for years flawless...and if the straingauge is broken it schouldnt work at all, right?
Mybe the delta just realized that i was to print parts for my new project a duet Voron 2.4 and decided to sabotage meGuess i dont want to spend another 70 bucks for a new effector. MAybe someone had similar problems already
My M122m122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later Board ID: 08DDM-9FAM2-LW4S8-6J9FD-3S06S-9MZ7X Used output buffers: 5 of 24 (18 max) === RTOS === Static ram: 23876 Dynamic ram: 74560 of which 0 recycled Never used RAM 15980, free system stack 116 words Tasks: NETWORK(ready,13.9%,238) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,303) MAIN(running,85.2%,441) IDLE(ready,0.9%,29), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:01:51 ago, cause: software Last software reset at 2021-12-07 11:36, reason: User, GCodes spinning, available RAM 15980, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00417000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 28.6, current 30.7, max 31.0 Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 53428, standstill, SG min/max 0/1023 Driver 1: position 53428, standstill, SG min/max 0/304 Driver 2: position 53428, standstill, SG min/max 0/1023 Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2021-12-07 11:38:28 Cache data hit count 3920433521 Slowest loop: 6.66ms; fastest: 0.15ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.3ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 13415ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 84, completed moves 84, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 15.95ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address ec:fa:bc:0b:f5:3d WiFi Vcc 3.42, reset reason Turned on by main processor WiFi flash size 4194304, free heap 21248 WiFi IP address 192.168.178.50 WiFi signal strength -57dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
and my Config.g
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 08 2020 17:21:54 GMT+0100 (MitteleuropƤische Normalzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name M665 R172.907 L364.85 B120 H415 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X3.97 Y-3.31 Z-0.65 ; put your endstop adjustments here, or let auto calibration find them ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160.00 Y160.00 Z160.00 E408,75 ; set steps per mm M566 X2000.00 Y2000.00 Z2000.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X25000.00 Y25000.00 Z25000.00 E1200.00 ; set maximum speeds (mm/min) M201 X4000.00 Y4000.00 Z4000.00 E1000.00 ; set accelerations (mm/s^2) 2000 standard M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; set minimum Z ; Endstops M574 X2 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z2 S1 P"zstop" ; Z-Probe M558 P5 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000 A005 ; set Z probe type to effector and the dive height + speeds p5 G31 P100 X0 Y0 Z-0.43 ; z-0.60 babystep -0.170 M557 R100 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S130 ; set temperature limit for heater 0 to 120C M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S290 ; set temperature limit for heater 1 to 280C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan2" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined M575 P1 B57600 S1 T0 G29 S1 ;M579 x1.016 Y1.016 Z1.000 M501
Next day..next try..
To exclude a bad crimp i re-crimped the 8 pin connector on the smart effector. But same behaviour. if i program it with sensitivity of 10 i get readings before probing ..if i change it to 15 he misses readings and rams the nozzle into bed.
Anything else i could do to find the cause of that problem? -
Have anything physically changed with the mount? Is something loose?
@phaedrux
No..checked all ball ends..nuts...hotend..nothing loose...even tried to loosen it. nothing changed between these 2 prints, when it starts to ram into bed. tried smaller build areas for probing ( as i made the mag arms new this year and they are 10mm shorter, so the kinematic gets a little bit unstable if i tired the whole 300mm diameter for probing) Very strange....ordered a new effector and hope to get it this week. -
Just received the new effector. its a Rev 3 Effector..
is it normal that the coldend dont sits flush to the pcb?
the palstic nut is just wurned on with hand...would need force to make the coldend flush with pcb...or should i sand the hole in the pcb larger? -
@barracuda72 said in Smart effector lost nearly all sensivity:
If it's a little snug, yes you can do that.
BTW, still looking into your original sensitivity issue.
I've just assembled a Mk3; I found the heatsink to be a very tight fit in the PCB as well, but it did seat fully in when rotated a few times, like "screwing it in", before fitting the nut.
Had to sand the pcb a little bit...anyway
With the new effector it worked like charm again...so something must be wrong with the old one..as i never got any error LED flashing its strange..but the efforctor worked well for about 5 Years..
@barracuda72 yes there may well be some dame to the traces or connection points for the sensing components on one side of the board. Its not possible to say without close inspection.
