M84 error after upgrade to 3.3
@phaedrux Ok here we go The Error comes after i start print either during the Bed Probing or right after.
12/9/2021, 3:44:02 PM M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
Board ID: 08DGM-9T6BU-FG3S8-6J9DD-3S86R-KBKHF
Used output buffers: 6 of 24 (16 max)
Static ram: 23876
Dynamic ram: 75072 of which 0 recycled
Never used RAM 15468, free system stack 174 words
Tasks: NETWORK(ready,12.0%,246) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,86.4%,461) IDLE(ready,1.5%,29), total 100.0%
Owned mutexes:
Last reset 00:01:02 ago, cause: power up
Last software reset time unknown, reason: User, GCodes spinning, available RAM 15468, slot 0
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 18.9, current 24.0, max 24.2
Supply voltage: min 24.3, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-12-09 15:44:01
Cache data hit count 2273262020
Slowest loop: 5.70ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 7.2ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 16.18ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.26
WiFi MAC address b4:e6:2d:60:31:eb
WiFi Vcc 3.28, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24792
WiFi IP address 10.0.0.169
WiFi signal strength -64dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Config.g
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Dec 06 2021 04:14:12 GMT-0600 (Central Standard Time); General preferences
M550 P"My Hacked Ender 3" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P3 S0 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z400.00 E97.18 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X850 Y850 Z850 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-3 Y-3 Z0 S1 ; set axis minima
M208 X235 Y235 Z255 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P5 C"^!zprobe.in" H5 F240 T9000 ; set Z probe type to switch and the dive height + speeds
G31 P1000 X-47 Y-11 Z1.90 ; set Z probe trigger value, offset and trigger height
M557 X12:193 Y16:214 S25 ; define mesh grid; Heaters
M307 H0 B1 S1.50 ; enable bang-bang mode for the bed heater and set PWM limit
M143 H0 S150 ; set temperature limit for heater 0 to 150C
M307 H1 B0 S0.00 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T65 ; set fan 1 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss12/9/2021, 3:47:32 PM M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: bad model parameters
Error: bad model parameters - WiFi -
@mringersoll said in M84 error after upgrade to 3.3:
Yes, and what exactly is the error?
@phaedrux sorry here is the error also the print head is like 6mm off the bed when it starts printing but for some reason the display says it is at.30 for Z axis i am really confused with this please help 3.2.2 works fine so maybe just go back to 3.2.2 and stay there i guess.
12/10/2021, 3:04:49 PM Error: in GCode file line 20 column 6: M84: expected number after 'E'
same error just different lines and columns depends the file i choose for printing.Mike
same error just different lines and columns depends the file i choose for printing.Please post that line of code which is generating the error.
@fcwilt
so how do i get to that line of code to post it? -
@fcwilt
and what do i use to open it to get the lineThanks
Thanks
It's a text file. You can open it in most any text editor - one with line numbers would be helpful.
Or you can also upload to the SYSTEM folder in the DWC and open it there.
@fcwilt
M84 E ; disable for more accurate probing,is what is says.
Also why is the Z axis staying up so high the nozzle is about 6mm from the bed. and during probing i does not go down much at all before it goes back up the probe is triggering way early not even close to the bed when I home the printer the probe works as expected don't get it.Mike
Well there is why you are getting an error. Whatever is generating that line of code is not putting the number(s) after the E.
If you use to work possibly the older firmware didn't handle that error properly or perhaps in the absence of any number(s) it used a default.
We would need to see your homing files first.
Have you made any changes to your config file? If so post it again.
If you change that line to M84 E0 that should solve that error, though I'm not sure it's related to your homing problem. For that we would need to see your homing files and start gcode as well.
@phaedrux Ok here are the homing files but my problem is the nozzle stays like 3mm above bed when it prints.
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H2 Z5 F9000 ; lift Z relative to current position
G1 H1 X-243 Y-241 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F9000 ; go back a few mm
G1 H1 X-243 Y-241 F600 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X59 Y27 F9000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F150 ; lift Z relative to current position
;G90 ; absolute positioning; homex.g
; called to home the X axis
G1 H1 X-240 F2400 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F9000 ; go back a few mm
G1 H1 X-240 F600 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F9000 ; lower Z again
G90 ; absolute positioning; homey.g
; called to home the Y axis
G1 H1 Y-240 F2400 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y5 F9000 ; go back a few mm
G1 H1 Y-240 F600 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning; homez.g
; called to home the Z axis
G1 X59 Y25 F9000 ; go to first probe point
;G90 ; absolute positioning -
M557 X12:193 Y16:214 S25 ; define mesh gridWhat type of Z probe do you have?
Have you calibrated the z trigger height recently?
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probeWhat do you have in your slicer start gcode? I don't see anything wrong with your homing files.
@phaedrux Hello Again
I am using an EZabl for my probe and calibration about 2 days ago. I am using an Ender 3 Cura or simplfy3d slicer i tried to copy and paste to get my cura Start G code but does not work.Mike
@phaedrux Hello
Here is the start gcode from my slicer;M75 ; Start Print Timer and Engage Fil Sensor if USB Printing
G92 E0 ; Reset Extruder distance to 0
G1 E-2 ; Retracts filament to prevent blobs during probing
M84 E ; Disable E Motor for probe accuracy on direct drive systems
G28 ; home all axes
G28 Z ; home Z to get more accurate Z position
G29; EZABL mesh generation
G4 S10; wait for heaters to recoverM117 Purge extruder
G92 E0 ; reset extruder
G1 Z1.0 F3000 ; move z up little
G1 X0.16 Y26 Z0.3 F5000.0 ; move to start-line position
G1 X0.16 Y110.0 Z0.3 F750.0 E15 ; draw 1st line
G1 X0.6 Y110.0 Z0.3 F3000.0 ; move to side a little
G1 X0.4 Y13 Z0.3 F730.0 E12 ; draw 2nd line
G1 Z1.0 F3000 ; move z up littleM117 Printing.....
@phaedrux Hello
G28 ; home all axes
Where did that code come from?
@fcwilt Hello That is the Start gcode from my Slicer like i was asked for.
Also as i said before there is something triggering my Z probe way off the print bed i mean the probe is nowhere near the bed when it triggers. When i run G28 the probe works as expected goes close to bed, anything after the probe might get 4mm from bed so something is messing with the Z Probe.Mike
Mike
You mentioned Cura and Simplify3D as the slicers you use. Is that correct?
Which slicer was the code you post from?
Was this code you entered in the user code location in the slicer or was it completely generated by the slicer?
Thanks.
@fcwilt Hello
slicer generated with the addition for mesh bed probing -
@fcwilt oh sorry Cura 4.12.1
