M84 error after upgrade to 3.3
@phaedrux sorry here is the error also the print head is like 6mm off the bed when it starts printing but for some reason the display says it is at.30 for Z axis i am really confused with this please help 3.2.2 works fine so maybe just go back to 3.2.2 and stay there i guess.
12/10/2021, 3:04:49 PM Error: in GCode file line 20 column 6: M84: expected number after 'E'
same error just different lines and columns depends the file i choose for printing.Mike
@mringersoll said in M84 error after upgrade to 3.3:
same error just different lines and columns depends the file i choose for printing.Please post that line of code which is generating the error.
@fcwilt
so how do i get to that line of code to post it? -
@fcwilt
and what do i use to open it to get the lineThanks
Thanks
It's a text file. You can open it in most any text editor - one with line numbers would be helpful.
Or you can also upload to the SYSTEM folder in the DWC and open it there.
@fcwilt
M84 E ; disable for more accurate probing,is what is says.
Also why is the Z axis staying up so high the nozzle is about 6mm from the bed. and during probing i does not go down much at all before it goes back up the probe is triggering way early not even close to the bed when I home the printer the probe works as expected don't get it.Mike
Well there is why you are getting an error. Whatever is generating that line of code is not putting the number(s) after the E.
If you use to work possibly the older firmware didn't handle that error properly or perhaps in the absence of any number(s) it used a default.
We would need to see your homing files first.
Have you made any changes to your config file? If so post it again.
If you change that line to M84 E0 that should solve that error, though I'm not sure it's related to your homing problem. For that we would need to see your homing files and start gcode as well.
@phaedrux Ok here are the homing files but my problem is the nozzle stays like 3mm above bed when it prints.
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Dec 06 2021 04:14:12 GMT-0600 (Central Standard Time)
G91 ; relative positioning
G1 H2 Z5 F9000 ; lift Z relative to current position
G1 H1 X-243 Y-241 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F9000 ; go back a few mm
G1 H1 X-243 Y-241 F600 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X59 Y27 F9000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F150 ; lift Z relative to current position
;G90 ; absolute positioning; homex.g
; called to home the X axis
G1 H1 X-240 F2400 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F9000 ; go back a few mm
G1 H1 X-240 F600 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F9000 ; lower Z again
G90 ; absolute positioning; homey.g
; called to home the Y axis
G1 H1 Y-240 F2400 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y5 F9000 ; go back a few mm
G1 H1 Y-240 F600 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning; homez.g
; called to home the Z axis
G1 X59 Y25 F9000 ; go to first probe point
;G90 ; absolute positioning -
M558 P5 C"^!zprobe.in" H5 F240 T9000 ; set Z probe type to switch and the dive height + speeds
G31 P1000 X-47 Y-11 Z1.90 ; set Z probe trigger value, offset and trigger height
M557 X12:193 Y16:214 S25 ; define mesh gridWhat type of Z probe do you have?
Have you calibrated the z trigger height recently?
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probeWhat do you have in your slicer start gcode? I don't see anything wrong with your homing files.
@phaedrux Hello Again
I am using an EZabl for my probe and calibration about 2 days ago. I am using an Ender 3 Cura or simplfy3d slicer i tried to copy and paste to get my cura Start G code but does not work.Mike
@phaedrux Hello
Here is the start gcode from my slicer;M75 ; Start Print Timer and Engage Fil Sensor if USB Printing
G92 E0 ; Reset Extruder distance to 0
G1 E-2 ; Retracts filament to prevent blobs during probing
M84 E ; Disable E Motor for probe accuracy on direct drive systems
G28 ; home all axes
G28 Z ; home Z to get more accurate Z position
G29; EZABL mesh generation
G4 S10; wait for heaters to recoverM117 Purge extruder
G92 E0 ; reset extruder
G1 Z1.0 F3000 ; move z up little
G1 X0.16 Y26 Z0.3 F5000.0 ; move to start-line position
G1 X0.16 Y110.0 Z0.3 F750.0 E15 ; draw 1st line
G1 X0.6 Y110.0 Z0.3 F3000.0 ; move to side a little
G1 X0.4 Y13 Z0.3 F730.0 E12 ; draw 2nd line
G1 Z1.0 F3000 ; move z up littleM117 Printing.....
@phaedrux Hello
G28 ; home all axes
Where did that code come from?
@fcwilt Hello That is the Start gcode from my Slicer like i was asked for.
Also as i said before there is something triggering my Z probe way off the print bed i mean the probe is nowhere near the bed when it triggers. When i run G28 the probe works as expected goes close to bed, anything after the probe might get 4mm from bed so something is messing with the Z Probe.Mike
Mike
You mentioned Cura and Simplify3D as the slicers you use. Is that correct?
Which slicer was the code you post from?
Was this code you entered in the user code location in the slicer or was it completely generated by the slicer?
@fcwilt Hello
slicer generated with the addition for mesh bed probing -
@fcwilt oh sorry Cura 4.12.1
@fcwilt Hello
well not sure how to fix it but when i turn on the printer in the console menu of my Paneldue there are two lines back to back that say bad model perimeter it is at the beginning seems to be after the network stuff than wifi starts so how do i start all over with this firmware and such. -
I would suspect your M307 commands in the heater section.
The first is M307 H0 B1 S1.5. The S parameter is limited to 0 to 1.
The second is M307 H1 B0 S0.00. While the S parameter is within range it doesn't make sense.
Try setting them both to 1.0 and check again.
